Glovebox's light !!!
hey guys i have a problem with my glovebox's light, it's not working anymore, and i cant find where the bulb light is located, it worked in the first couple days then it turned off aand never come back on !!
so simple yet so effective and they have to remove them lol.
someone should start making these independently, could probably make some money off of it if you can get enough people to buy... maybe somehow make it like a plug-and-play type deal with the wires behind the glovebox possibly?...
would it work?
would it work?
Does not come stock with car, so you'll have to install them..
Two ways..
1. Just tap into constand power wire to stay on all the time(easy install)
2. Tap into constant power wire, install switch to make them turn on when it's open...(moderate install)
Two ways..
someone should make a diy for this idk which switch to get
from what i see a lot of the older cars have it and it suxs. most of them dont work since the radiator fan a blows crap on it over time. moisture/water gets in. if it was a LED the temp from the engine will dim that after the first few miles.
anyways OP. it would be nice to have a light in the glove box though.
