has anyone heard of hushmat???
Old May 17, 2006 | 07:47 PM
JINeration's Avatar
Default has anyone heard of hushmat???
well its kinda like dynamat buh easier to install "
anyone heard of it??
Old May 17, 2006 | 08:08 PM
nytlemgr's Avatar
can't say i have.
Old May 17, 2006 | 10:36 PM
tweetertc's Avatar
yeah... its bascially the exact same thing... its a little easier to work with if your new to it... otherwise... its just like working with every other sound dampener...
Old May 18, 2006 | 02:26 AM
JINeration's Avatar
so it would just work the same as dyna kuz its WAY CHEAPER then dyna
Old May 18, 2006 | 06:04 AM
bboyizzy's Avatar
never heard of it
Old May 18, 2006 | 07:59 AM
-Keith-'s Avatar
how much is way cheaper? Theres others ones that are posted on here that are pretty cheap
Old May 18, 2006 | 08:01 AM
mandangalo's Avatar
www.sounddeadenershowdown.com
Old May 18, 2006 | 02:35 PM
mandos's Avatar
All mat deadeners do the same thing.
Add mass to a panel to make it heavier, lower vibration.
Biggest difference between them is what they are made of. Asphalt obviously smells like tar and has a lower temp resistance. Rubber Butyl has a very high temp resistance and doesn't smell at all.
Old May 18, 2006 | 08:19 PM
retrodrive's Avatar
Actually smell is secondary to the ability to stick to vertical surfaces. Do you know what mess it can make when your mat starts falling off when the car heats up under the sun?
I say go RAAMmat. I have used it for over 6 years on my cars and it has not fallen off or ever smelled.
Old May 18, 2006 | 08:28 PM
mandos's Avatar
That's where heat resistance comes in.
Granted, I know of quite a few old eDead(asphalt) installations involving completely upside down surfaces that are just fine. That said, butyl is far superior to asphalt in the withstanding extreme heat dept.
Old May 18, 2006 | 08:29 PM
titolito's Avatar
I used RAAMmat myself. I vouch that there is no smell....
Well, not entirely true. When I opened up the package that mat came in, it had a distinct smell, but not bad. Once I put it all in my tC, I had a smell for about a day and then it was gone. Then I put the ensolite foam on top of the mat and that definately had a smell. Not the foam itself, but the adhesive used to stick the foam to the mat. That smell lasted for about 3 or 4 days. After that, no smell at all. It's wasn't a bad smell either.
richard_rsp
Apr 6, 2017 09:37 PM
kb1sxv
Oct 21, 2015 05:00 PM
Luna7ic
Sep 28, 2015 03:30 PM
user9430961
Sep 15, 2015 03:16 AM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
