Head Unit will not turn on
Originally Posted by Sciontistical_One
Start with the simple stuff first... is the key in the ignition? Did you check your fuses? Did you disconnect your battery? More importantly, did you re-connect your battery?
Originally Posted by Jiggaman
If you keep blowing fuses...your wiring may not be right.
even my stock HU wont power on anymore.. wtf
sounds like you mixed up a wire somewhere and shorting power out, thus blowing fuses.
it's not always about color matching... it's all about making sure you got the speakers, the power, and everything else wired properly.
can't help much further without seeing what you've done.
