HELP!!!!!!!!
Old Mar 14, 2008 | 10:32 PM
frenchaj09's Avatar
Scion Noics
Default HELP!!!!!!!!
Alrighty, so im trying to install LED bulbs in my door handle place (on the driver side door). I need to know which wire (color) is the power wire.
IF ANY ONE CAN!! Please respond ASAP, i have to be on the road in 1/2 hour.
Old Mar 15, 2008 | 01:45 AM
rvpps2rocks's Avatar
use a multimeter and test it..
Old Mar 15, 2008 | 02:06 AM
arkenzo's Avatar
What color wires you got? Usually white or red are power...black would be ground, what colors do you have?
Old Mar 15, 2008 | 05:08 AM
frenchaj09's Avatar
Scion Noics
Well I fixxd it. Ran a wire from the inside of the door, through the wireharness between the door and main body, and spliced right into a permanent power supply and ground.
Didnt have a multimeter handy... i bet that wouldve worked...lol
And Ark: I had purple, pink, 2 blacks, 2 reds, a white-black mix, orange, blue, and green.
Take your pick... lol. None of them worked... so :-P
Old Mar 16, 2008 | 05:10 AM
combatsteve's Avatar
not stock wiring...multimeter is the only way to check unless someone has a wiring diagram.
Old Mar 17, 2008 | 01:49 AM
frenchaj09's Avatar
Scion Noics
lol... wished i had that when I was doing the mod.... Wouldve cut 7 hours off of my project time....
Old Mar 17, 2008 | 06:55 PM
just go buy a cheap 20$ one
Old Mar 18, 2008 | 12:29 AM
frenchaj09's Avatar
Scion Noics
multimeter? I actualyl had access to one and completely forgot about it... lol
