help on AVIC D3 in 08 tC
Old Feb 17, 2008 | 12:17 PM
efftrain's Avatar
Default help on AVIC D3 in 08 tC
i have a question that doesn't seem to be addressed in any other posts about D3 install, as well as checked avic411.
i have an 08 tC, which means i have 6 speakers (two tweeters and the ones in the door) and factory sub.
if i install the D3, will i be able to use all of this?
the reason i ask is i was reading through the install manual for the D3 on pioneers site, and it says for the power, if you have sub, then no rear speakers. this is my understanding. if i am incorrect, please correct me.
if this has be answered else where in another post, i apoligize, could you please direct me to it.
Old Feb 17, 2008 | 04:40 PM
megrog2's Avatar
Does the 6" sub have a separate amp to power it that's not in the stock radio? if so you may not be able to connect it to the D3.
Old Feb 17, 2008 | 06:47 PM
tweetertc's Avatar
with normal hook up you will only get your components the front and coaxials in the rear... no sub... but i can assure you it could be done.. i have done it to many other cars with factory subs... such as cobalt ss, ford explorer, expedition, ect... it just takes some figuring out... my best guess is you only need to find the turn on wire and the audio signal wires... run RCA'sand remote from your deck to the sub .... splice them in...and your good to go...
Old Feb 18, 2008 | 02:25 AM
blazeplacid's Avatar
yeah take out the factory headunit and see if the sub is just plugged in with a harness
the bazooka subs was like that with just a harness
The fronts and rear wll work with the d3 out of the box
Old Feb 19, 2008 | 03:53 AM
unxpectederror's Avatar
the sub is spliced into the front speakers so you dont have to worry about anything.. just wire as normal just make sure the sub has a power line going to it so it turns on when the car does other wise you wont have anything coming from the sub..
Old Feb 19, 2008 | 01:47 PM
efftrain's Avatar
Thanks all for the info.
i actually spoke with crutchfield reps, and though toyota won't release the wiring diagrams for the car internals, they have installed the D3 into an 08, and they say it works no problem. this is based on hands on research, but won't be shown on their master sheets, probably for the reason that unepectederror metioned, since it's spliced it.
Thanks for all the help. now i just need my next pay check so i can afford it.
O5_TRD_tC
Feb 18, 2015 09:01 PM
NYCtC
11
Dec 8, 2005 05:36 AM
BADS33D
Oct 1, 2005 07:31 AM
Eppopipe
Sep 25, 2005 02:28 PM
Eppopipe
Sep 11, 2005 03:11 PM
