HELP!!! Headunit Not Turning On
Old Jun 4, 2005 | 12:44 AM
KINGxOFxSKA's Avatar
Unique Scionikz
Default HELP!!! Headunit Not Turning On
so as i was driving out of my street like 10 min ago, i pushed the power button for the radio and i got no response. it was working fine this morning, and now it wont turn on? i didn't play with any wires or anything today. anyone know what the problem could be?
(and yes i tried a search 3 times with no avail) plz help!
Old Jun 4, 2005 | 01:08 AM
sciontc_mich's Avatar
well besides saying the obvious of going to the dealer..
the stock radio's have had problems. you could always check the fuse for the radio, but i bet you'll check it and it'll be fine.. a few of us have been lucky to have the problems with the radio, I went through three until it was finally fixed..
there was someone last fall, I think, who had the problem of the radio not powering up, and it turned out it was bad..
looks like you'll have to take it to the dealer and when they can't power it up either, you'll get a new one..
Old Jun 4, 2005 | 03:42 AM
Rivulent's Avatar
Default Re: HELP!!! Headunit Not Turning On
Is this a stock unit? Why did you play with the wires in the first place?
See if you can load any cds, if you can, your 12volt constant (yellow for aftermarket) is fine: In which case your accessory wire (red " ") is bad, grounded out, or a fuse blew. If it doesn't, your 12 volt probably has some bare wire and it touched ground. If your unit is stock, take it to a dealer.
Old Jun 4, 2005 | 04:22 AM
Unique Scionikz
i fixed it. i checked the fuses and sure enough one of them was blown.
and yes it is the stock headunit, but i do have an amp and a sub so i had played around with the wires before sometime in February.
Old Jun 4, 2005 | 04:52 AM
better double check your wiring or it might blow again.. well good, so it was the fuse.. glad it was a simple fix..
Old Jun 4, 2005 | 05:05 AM
Unique Scionikz
yeh i checked the wiring before i checked the fuse... everything is fine. thx for the fuse tip
Old Apr 10, 2006 | 02:18 AM
Viperj_13's Avatar
I know this hasn't been discussed since 6/3/05, but I have a similar problem. I’m just having hell with the audio in this car. First all 3 fuses for my subs die (2 on amp one in engine bay), replaced them, then the box breaks. I repair box and then amp blows. Now, waiting for my new amp under warranty, I’m riding stock. The head unit will not turn on at all. It was really random, I was driving and as I was pulling into my grandma's driveway, it declines first then levels out, and it’s like a bump I go over it and then it stopped working. The radio just shut off, it was really weird. I checked the fuses. If I'm not mistaken it’s a 30 amp fuse in the engine bay, red in color? It was good. I haven't check the wiring, but I won't. I'll be taking it to the dealer soon telling them that I did have a system in there, but this is my problem. Also I don't know if this is related. But the car charger in the center console (the cigarette lighter looking thing) Stop functioning the same day. So if anyone has any tips. Please help me out.
Old Jul 2, 2006 | 02:34 AM
Nightsnake's Avatar
My stock HU just stopped working for me too. I was cutting the wires that went to my stock Bazooka sub and silly me i forgot to disconnect the ground wire to my battery and there was smoke from the wires for a split second. What do you guys think of this? I checked for a blown fuse but i don't really know what i am looking for. Lol. HELP PLEASE!!!
Old Jul 2, 2006 | 02:42 AM
L4rry_B1rd's Avatar
check the accessory fuse in the fuse box under the steering wheel. I think its #73 but I could be mistaken. Samething happened to me. Was doing stuff with my audio, connected the negative to open hatch, forgot to disconnect and some wires touched. should just be a blown fuse
Old Jul 2, 2006 | 03:06 AM
Nightsnake's Avatar
Yeah that's what i thought but i can't find a fuse that looks like it would be blown but then again i have never seen a blown fuse. What should i be looking for?
Old Jul 2, 2006 | 03:19 AM
Nightsnake's Avatar
Plus i just looked under the steering wheel and also above the pedals and i can't find #73 fuse so i don't know what to do now. Lol.
Old Jul 2, 2006 | 03:44 AM
L4rry_B1rd's Avatar
you have to look in the fuse box...
and if you look at a fuse, if the metal piece inside of it is broken, then its blown
Old Jul 2, 2006 | 04:45 AM
Nightsnake's Avatar
Yeah dude i looked in the fuse box. Do you know what amp it is? That might narrow it down a bit. Plus is it just a small fuse or one of the bigger ones?
Old Jul 2, 2006 | 02:49 PM
Nightsnake's Avatar
I have finnaly found it. It was a 20amp in a yellow/green color under the hood. It was on the far right of the second row that is closest to the firewall. I hope this picture shows. If you go here there will be a picture to see which one i am talking about: http://tcover.net/tCover_Install_ManualComp_2_1.pdf. But now everything works fine. All i need now is another fuse just in case i need another one in the future.
Old Jul 6, 2006 | 05:16 AM
davetex's Avatar
Default 2005 tc
I have the same problem with my radio. I guess one of the wires on my amp touched while I was taking my speakers out (even though the fuse was removed on my amp) and my head unit just shut off and won't turn on. I checked the fuse under the hood and it's fine...is there another fuse for the head unit anywhere? I need to solve this problem fast, I miss music. Any help at all is greatly appreciated.
Old Jul 16, 2006 | 08:53 AM
Nightsnake's Avatar
Yeah in another thread there was talk of another fuse that is above the steering coloum. They had to manover themselves into the coloum in order to find it but at least you know it's there.
excessads
10
Dec 2, 2015 09:09 PM
setpol
Feb 17, 2015 11:33 PM
bobc04
Dec 8, 2014 05:01 PM
crocker
Dec 2, 2014 03:44 AM
