Help: HVAC/shifter light out
Does anyone know why my shifter and HVAC light won't turn on? I already checked the fuses. When the headlights are off, the HVAC area is lit, however when I turn on my headlights, the HVAC area turns off. Anyone know how I can fix this? I can't see the time or where the HVAC is blowing at night.
Sure is...another common problem is that my radio doesn't work either, well the radio stations at least, my iPod works fine with it... any solution? I recall seeing a soldering solution for the radio.
Can you list each and every lights that doesn't work??
If the fuse is the problem then gauges, climate control, cubby hole, shifter all doesn't light up..
Depends on which lights works and doesn't work, I can diagnose it for you..
I don't think its the fuse then because I think everything but my shifter light and the little area that shows where the air is blowing is out. I'll check later today to see if any others are out.
wiltonhall
Jun 23, 2025 10:09 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
