Help LOUD audio noise all of a sudden...
Old Jul 2, 2008 | 09:04 PM
jzibit17's Avatar
Default Help LOUD audio noise all of a sudden...
Hey everyone I need your guys help on trying to solve my audio problem
Setup: Pioneer avic-D3, 2 channel amp for the front speakers and a 2 channel amp for the subs. 1.5F capacitor. Front speakers are components and rear speakers are factory and not amplified. The power is being run on one side of the car and the RCA,signal and the speakers wires are on the other side of the car.
The problem: Today while changing the air filter and listening to music the cross over terminals touched metal and suddenly the subs thumped at a constant high volume. Right now when I turn the key one click the subs have that some thump and music coming out of all the speakers sounds good but when I turn the key one more time both front speakers have a high static noise sound coming out of them. The static noise remains constant from volume zero and on… When I roll the windows up and down you can hear them being rolled up or down out of the front speakers. When I turn the car on the static noise changes to a winding noise and remains at a constant loud volume from volume zero and on. FYI the rear speakers don’t have a problem at all.
What I have tried…
1) Reconnected the car battery
2) Reconnected the speaker wires from the crossover that touched the metal
3) Reconnected all the cables from the back of the AVIC-D3 including signal wire and RCA’s
4) Reconnected power, ground, signal and rca from both amps.
thanks in advance
Old Jul 2, 2008 | 10:12 PM
ninjaionsobe's Avatar
had that happen on my old car the cheap way around the problem was to put a rca noise filter between the d3 and the amp
check all your fuses and grounds
i would also replace the connector or cut of the end of the wire that grounded out for a new clean contact point
Old Jul 3, 2008 | 01:45 AM
datdude1119's Avatar
yeah check all of the fuses, and all of the other stuff that other guy said lol
Old Jul 3, 2008 | 01:49 AM
CarbonXe's Avatar
LOUD NOISES!
Sorry, I just couldn't resist after reading the title.
Old Jul 3, 2008 | 04:27 PM
jzibit17's Avatar
k ill check the fuses i think i downloaded a diagram from here but i doubt it might be the fuse dont you think? I mean all speakers have sound coming out them....
Old Jul 3, 2008 | 06:11 PM
check your rca maybe they are touching the grounds on the head unit or amp just back them off
Old Jul 4, 2008 | 04:38 AM
jzibit17's Avatar
about the RCA i know they are not touching anything cuz after disconnecting them from the back of the head unit i reconnected them and used electric tape around them. I even switched the ones connected to the amp running to the subs and the speaker and i still have the same problem
Old Jul 5, 2008 | 07:23 PM
jzibit17's Avatar
any one knows which fuses i should check... Im beginning to run out of things to check on. I reconnected the deck and amps' ground and the background noise is still there...
Old Jul 8, 2008 | 04:25 AM
wish i could be more help at this point i would say go for the
http://www.scosche.com/products/sfID...productID/1097
Part Number: ES034
Product Name: GROUND LOOP ISOLATOR
Description:
Ground Loop Isolator
pick them up at walmart and return it if it doesn't help
had them on my avic-n1 both amps
Old Jul 20, 2008 | 12:23 AM
rocketgyrl's Avatar
Amplifier's freak out when the speaker outputs are shorted to ground, and damage usually happens. It sounds like when the crossover terminals touched ground - the input filters on the amplifier(s) were damaged.
Try disconnecting the RCAs and turn the system on. Is there noise? Roll the windows up and down (trying to induce noise).
Is there noise in both amplifiers? If not, swap the two, and see if the noise moves to the other speakers.
Is the amplifier under warranty?
kb1sxv
Oct 21, 2015 05:00 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
