HELP Short Circuited my Cigarette Outlet
UPDATE: I took out every fuse in the footwell and none were blown. When i was hardwiring my LCD into the cigarette adapter, i accidentally let the positive and negative wires connect. They sparked and now i have to power coming out of either cigarette plug. I assumed it was a fuse, but like i said, i checked all the fuses by the pedals and none of them were blown.
Any other possibilities?
there is one more fuse..... its a glass fuse that you can find on the wires that connect to the cig lighter. its probably wrapped with tons of electical tape, but i know its there for sure...
i ran into the same problem you did with the incorrect wiring and i blew a fuse, but none of the fuses were blown under the dash.. so i took it into the dealer and they fixed it for me under warranty... just follow the wire from the plug to the wires around the shift **** and see if you can find it.... if not, you might have to start ripping off the electrical tape from the wires.
good luck!
good luck!
good luck!
good luck!
It's a 16 fuse on the side closer to the driver not to the firewall afik. Just get a matching fuse and try replacing it, sometimes they don't look blown, but the same thing happened to me and it was that fuse.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
airmankevin1
Nov 17, 2015 05:44 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
