How to remove / solder a PLCC LED for gauge / hvac work PICS
Old Feb 24, 2009 | 01:15 AM
  #121
sinningxlove's Avatar
Originally Posted by Garage1217
Bump!
so how much does it cost for the gage clusters? and do you do the heat controls too?
Old Feb 24, 2009 | 03:26 AM
  #122
Garage1217's Avatar
Originally Posted by sinningxlove
alright so how much would it cost to have the gage clusters done? do you also do the heat controls too?
Price depends on what you would like to have done. Examples of work and prices are listed on my site.
http://www.garage1217.com/album1_015.htm
Old Feb 27, 2009 | 03:34 PM
  #123
Garage1217's Avatar
Friday BUMP!
Old Feb 27, 2009 | 06:18 PM
  #124
Joyride's Avatar
Ordered these last night, cant wait to get them!
Old Feb 27, 2009 | 07:02 PM
  #125
Garage1217's Avatar
Already shipped!
Old Mar 12, 2009 | 08:08 PM
  #126
Garage1217's Avatar
Almost the weekend BUMP!
Old Mar 25, 2009 | 07:19 PM
  #127
Garage1217's Avatar
BUMP!
Old Mar 30, 2009 | 04:12 PM
  #128
Garage1217's Avatar
Monday BUMP!
Old Apr 12, 2009 | 03:19 AM
  #129
Garage1217's Avatar
Easter BUMP!
Old Apr 23, 2009 | 01:35 AM
  #130
Garage1217's Avatar
Evening BUMP!
Old May 3, 2009 | 06:03 PM
  #131
Garage1217's Avatar
Sunday BUMP!
Old May 15, 2009 | 01:36 AM
  #132
Garage1217's Avatar
Almost FRIDAY bump!
Old May 16, 2009 | 11:42 AM
  #133
Edgaras's Avatar
id like to do this to my tc, however im a little frightened. im in Lithuania and its hard to find a tc, not to mention how hard it is to find a tc led swapper.
i have a little experience in solding, so its not that new to me.
therefore ive got a few quetions:
1) do you swap oem orange leds with white ones and paint the back of the cluster in desired color? if so, what paint do you use? or you use light filter (dont know how its called in english. a transparent sheet in whatever color?)
2) if the method i described above is good the one that can be used, can i buy only the leds from u or another swapper?
thanks for your time,
luv ur work :D
Old May 16, 2009 | 01:59 PM
  #134
engifineer's Avatar
If you want he gauge faces all the same colors (lines and numbers the same) then you just use the color led you want. So if you wanted blue, you would just use blue leds.
I will add though that if you want pink or purple, dont use pink or purple leds. There is no such thing as a true pink led.. so they add a phosphourescent coating to make the color.. which has been proven to fade over time. Purple is the same and is many times created by using UV leds, which are bad for your eyes.
So, for the above, or if you want to create multitone look on the faces (like blue numbers, white lines for example) then you use white leds and order a colored translucent film to apply to the backs where you want the other colors. If you do the two tone look using the colored film, I recommend doing the resistor swap on the gauges as well to make them a bit brighter. (Just to clarify, you ALWAYS need the resistor and regulator swap on the HVAC unless you are using red leds)
For warning lights, turn signals and the HVAC buttons you can just buy the correct color leds for each one since they are all lit by individual leds.
Any of us that do the swaps can sell you the colored film, leds, resistors, etc that you need.
Old May 20, 2009 | 03:04 AM
  #135
Mikeydizzle's Avatar
im glad this topic is still active. i have a few questions. i have a little experience with soldering but never small leds and stuff. how would you rate this conversion in difficulty? and about how long does it take from disassembly to reassembly? if i was to send it to you about how long is the turnover time? thanks.
Old May 24, 2009 | 02:51 AM
  #136
Garage1217's Avatar
Turn arouns is super fast. I perform the work the day I get the items and ship the next via express mail 1-2 day shipping which is included in the price of any of my gauge cluster + hvac swaps. Difficulty depends totally on your soldering experience. If you have soldered any basic SMD devices, you should be fine.
Old May 24, 2009 | 04:50 AM
  #137
it seems pretty straight forward. i think i might take it on. i was thinking about going to a pull and save and rippin out a gauge cluster to try it out on. this way if i mess it up permanently im only out the few bucks it cost at the junk yard.
Old May 25, 2009 | 05:23 AM
  #138
Garage1217's Avatar
Very smart idea!
Old May 25, 2009 | 05:35 AM
  #139
Very smart idea!
Yes. I get that a lot.
... kidding
Old Jun 5, 2009 | 10:25 PM
  #140
Garage1217's Avatar
FRIDAY BUMP! Thank goodness for the weekends!
