How to take out side a pillar and molding
Old Mar 15, 2009 | 10:18 PM
psepter's Avatar
Default How to take out side a pillar and molding
I'm getting xm and hiding antenna by putting it in sunroof but I need help taking off a pillar and the rubber molding any pics or tips
Old Mar 15, 2009 | 10:58 PM
BZinn1's Avatar
To take out he front pillar at windshield in a car without side airbags,just grab it at about 6 inches down from roof and pull out,for a car with side airbags it is a lot harder as it is held by a pin and clip at the same location,same process but battery has to be disconnected and you have to be a lot more carefull.once you get panel a few inches out at top you will see the piece that goes to the clip in pillar and that plastic piece has to be literally torn out of the pillar and a new one replaced. on reassembly,couple of dollars at dealership.
Old Mar 15, 2009 | 11:17 PM
DivisionbyZero's Avatar
do yourself a favor, and position the antenna where it will be mounted and drive around for 1/2 an hour to make sure your reception is ok, both with the sunroof open and closed.
you'll thank youself later.
Old Mar 16, 2009 | 12:11 AM
psepter's Avatar
Yeah I will others have done what I am gonna do n they said reception is good
Old Mar 16, 2009 | 06:22 PM
lbjshaq2345's Avatar
Run the wire under the black trim line, no pillar removal necessary and the wire is never visible and perfectly secure.
thegracin
Scion tC 2G Aero & Exterior
Mar 24, 2015 04:35 PM
lunchbx05
Dec 29, 2014 07:53 PM
crystaljukebox_com
39
May 14, 2004 04:55 AM
ToyTuners
Nov 4, 2003 07:17 AM
