I need constant power
I was looking for a wire that can give me constant power for my underbody kit even when the the car is completely off. should i tap into the clock's power? if so, which wire would it be because there are a thousand different wires.
Read this thread it has ever wire you need.. I would recomend a constant wire at the ignition harness..
https://www.scionlife.com/forums/viewtopic.php?t=20742
Originally Posted by Scionarra
thanx for the help but i also need to know where this harness is located
I think you should run your own dedicated line. It's safer. This is because stock lines are rated for only so much amperage. If this amount of amperage is exceded, it can cause the wire to heat up, or at worst, start on fire. It won't simply blow the fuse because there is resistance in the line. In any case, running a seperate, dedicated, fused line, is almost always best!
If you've put in an aftermarket HU, and the current draw isn't too much, you could tap into the constant power wire going to the radio and add a switch there.
Or find something in the fuse box that's a constant.
didn't i answer this question yesterday..?
oh wait.. yes i did..
https://www.scionlife.com/forums/viewtopic.php?t=146127
ScionLife Editor
Jun 17, 2015 05:22 PM
sithscripter
Mar 31, 2004 04:02 AM
crystaljukebox_com
Feb 5, 2004 05:53 AM
