I need help my lights wont turn on...
OK well i bought 2 6leds from brightleds.com i installed the 1st one turn it on it looked great then turned it off. Installed the second one turned it on and it looked fine while i was putting the second one in the hole they just turned off....
Now they dont work at all and the amber side markers arent lighting up eather...
HELP !!
HELP !!
If u look on the bottom of the fuse box cover theres a diagram of which fuse does what. i dnt know if you knew this already just throwing it out there.
maybe a wire came loose when u put them in or something might wanna check that.
Check the area underneath where the Scion Security/Fogs Switch/etc Panel is. Not the piece that you can pull out, but underneath all that! There's a pic of the layout in your manual. A buddy of mine burnt out his tail lights, and this is where that fuse was. Its accessible by sticking your head in by the pedals and looking up. I hope this helps.
yea i checked there aswell ........ i took out very 10 amp fuse and all looked goood thanks for all the replys... if any one nows exactly which one it is or even what location it would be in.... leme know
THanks!
THanks!
That sucks bro. I thought it would for sure be there. Did you see pg 239 in your manual? #29. says "TAIL 10 A:..." You still might want to change that fuse. My buddy took his to the local Scion dealership and they replaced it for free! No questions asked. Also, I always disconnect my neg. bat terminal when I fiddle with the lights even though you don't have to. I blew the Lugg/Cargo area fuse and my buddy blew his tail fuse when the battery was connected. Funny part is, when he went to install the LEDs in his tails I told him he should disconnect the bat terminal. He shrugged me off. Then he proceeded to blow the fuse.
well i dought my rear light fuse has anything to do with it.... the wires looks fine and so do all of the fuses .. i even changed every single one with a good one and nothing..
it happend when i left the lights on and i was just putting the last led in the hole to turn it and i tapped it against the housing and boom they were out.. im going to the dealer 2 morrow 2 c whats up......
thanks for all the help
well i left my car at the dealer for a 2 days....
my problems were as follows
brake pedal wobbles alot...
air conditioning is not cold never was i just dont use it much.
Hatch rattle.
my day time running lights were not working..
and the recall on the sunroof..
only thing they did was the recall......
every thing else they said they could not duplicate my problem...
they blamed the air conditioning on my aftermarket radio...
the rattle on my subwoofers
and my lights on the hids i installed a week earlier which are from the new is350 and they say toYota on them!
I am ____sed and i still need help with my lights!
Hatch rattle.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
XTRMGMR
Dec 11, 2003 05:35 PM
