IGN wire
Old Feb 11, 2007 | 04:02 AM
david90's Avatar
Default IGN wire
Can somebody show me where to find the IGN wire?
Old Feb 11, 2007 | 04:07 AM
SquallLHeart's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=138455
Old Feb 11, 2007 | 04:24 AM
david90's Avatar
what's the size of the ign wire?
Are those quick splice reliable?
Old Feb 11, 2007 | 04:54 AM
exactly what are you trying to do?
quick splices are fine..
Old Feb 11, 2007 | 05:02 AM
TheQuietThings's Avatar
yea splicing the IGN is fine as long as you arent running too much power. i tapped my IGN for all my LEDs [currently 11 of them], and have not had a problem with it at all.
Old Feb 11, 2007 | 05:03 AM
david90's Avatar
Just trying to power a small circuit when the engine is running.
The way those quick splice devices cut into the wire makes make nervous. What size quick splice should I use on the ign wire?
Old Feb 12, 2007 | 11:40 PM
nodsetse's Avatar
Worst connectors ever made, so I suggest using something else. I know they're convenient so people like them, but the connection they make is marginal and they're prone to failure when compared to other types.
I suggest you take a look at these, which is what I use. You get 12 (easy to cut apart) for a reasonable price, they're reuseable, make a great connection and will not fail.
Old Feb 13, 2007 | 12:58 AM
david90's Avatar
Look at these? I don't see any pic or link
Old Feb 13, 2007 | 06:05 AM
click on "these"
Old Feb 14, 2007 | 01:03 AM
david90's Avatar
lol. it looks like plain text.
Old Feb 14, 2007 | 04:44 AM
eddo456's Avatar
If you are really that nervous then i suggest stripping the ign wire back and soldering on your new wire, then tapping it back up, solid connection, as long as you do it right.
Old Feb 14, 2007 | 04:52 AM
Scikotic-tC-'s Avatar
If you want somthing better get a add a circuit or use one of the open areas on the fuse box.
Old Feb 15, 2007 | 07:00 AM
david90's Avatar
What are other wires near the interior fuse box that is similar to the IGN wire? When I say similar I mean a wire that is hot when the engine is on like the ign wire.
Old Feb 15, 2007 | 01:00 PM
steedums's Avatar
what kind of circuit are you adding?
Old Feb 15, 2007 | 02:04 PM
david90's Avatar
I designed this PIC based circuit that would turn my headlights on/off depending on the ambient light level.
Old Feb 15, 2007 | 07:15 PM
nodsetse's Avatar
It's quick very easy to get to the wire behind the cigarette lighter. You can tap into the black wire going into the center rear of the lighter, which is hot when the key is in the acc position. I spliced in one of those euro style terminals there, to connect an additional wire, no prob at all.
Old Feb 16, 2007 | 12:48 AM
david90's Avatar
the wire that i want can't be hot when in acc, only in ign.
Rob54Monty
Feb 3, 2023 08:26 PM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
domincnTC
Aug 4, 2015 01:47 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
