Install 529T on a 881xp
I'm about to install two 529Ts in my 05 tc. i tried earlier to install the 530t and i foudn out those are all messed up. I just wanted to knwo if 1, do the 529Ts work on scion tc's for sure and 2, is there anythiing special i need to do in order to get this to work in my car? Thanks in advance.
If you want window control and sunroof, you need a 530t and a 529t
The 530 will do the windows up and down, and the 529 will open and close the sunroof.
I would suggest having a pro install them, cause them can be a _____ to install.
Jason
Jason
Jason
Jason
Team No Limitz
There isnt anything wrong with the DEI peices at all. I have done so many of them. The problem is you cant get the wires at the switches. You have to get them at the motors cause of the one touch that Scion does. That is where the problem lies. You have to go after the switches and down at the motors. They are not the funnest thing to install, but really not a issue when it comes to doing them.
NCBIGGJ is correct about getting the wires at the motors....but only with the 530t. I have found that with the tc it is way easier to use 2 529t's and get the wires at the switch. if you used more than one mod you should diode isolate each unit from one another so you dont get weird feed back
TheRedBox
31
Dec 2, 2003 04:53 PM
