Interior/Guage Cluster/LED question
How many LED's do I need to swap out the entire guage cluster and what type? Also, how many LED's do I need to swap out my center console as well as what type? Also, what type of LED's are the rear and front dome lights and the front(orange) blinkers? What type do I need to swap those and the rear reverse lights. Thank you so much if someone could please help.
https://www.scionlife.com/forums/viewtopic.php?t=37747
Originally Posted by panasoanic
12) If you just want to change the illumination of the gauge cluster, you will have to change 14 LEDs. 2 for the gas gauge, 2 for the temperature gauge, 5 for the speedometer, 2 for the LCD panel, and 3 for the tachometer. The LEDs are PLCC2 sized. You can find them at any electronics supply house. I personally bought mine from www.mouser.com. Look for LEDs that have a luminous flux (brightness) of more than 100 mcd. Otherwise, your gauge cluster will look dim.
http://home.cfl.rr.com/icdedppl/faq.html
this will help out with the rest.
and please... no led "replacement bulbs" for your exterior lighting
give it another 14... you count... 9 buttons, 3 inside lcd.. and then an extra 2 if you want your temp **** thingy another color.
and add 4 more if you want your indicator lights different as well.
bootlgr
Jan 26, 2016 01:22 AM
