Ipod Wire
Old Feb 19, 2009 | 03:36 AM
oxxomxxo's Avatar
Default Ipod Wire
Hey guys, i just bought a T8108, and i was wondering if anybody has the part number or if they have one for sale. It is the cable that goes from the back of the headunit/radio to the back of the center console. Thanks.
Old Feb 19, 2009 | 05:37 AM
SquallLHeart's Avatar
uhh... what year car do you have?
there's a bunch of cables that you need.. not just one.
Old Feb 19, 2009 | 11:32 AM
oxxomxxo's Avatar
i have a 2007 tC. i was under the impression you can have basically just two wires, one the that goes from the radio to the port underneath the hand rest, and another wire from the port to your ipod. Thanks.
Old Feb 19, 2009 | 07:48 PM
the wire from the back of the headunit to to the shifter area is built into the car... you don't need that.
you need the harness that connects to where that shifter area is to the armrest, and then from inside the armrest to the ipod. (2 pieces there)
Old Feb 20, 2009 | 12:47 AM
oxxomxxo's Avatar
SquallHeart, did you know by chance the part number for that wire that connects to the wire near the shifter area to the center console?
Old Mar 26, 2009 | 06:42 AM
cnstarz's Avatar
i am also looking for this. the 09 xb is set up similarly: 1: a cable that runs from the back of the headunit to the shifter area, and 2: another cable that runs from the shifter area to the armrest. i took the second cable out thinking i could just use this in my 07 tc, but the connector is different. so i too am looking for this cable's part number.
here's the deal tho: the T1808 radio (the same radio as the OP, also the 09 xb base radio) has an ipod input, in the back, for that ipod cable that runs from the headunit to the shifter area. however, when i was hooking up this headunit into my tC earlier today, i didn't see any other stray cables to be plugged into the headunit (specifically, the ipod cable that's supposed to run from the gear shifter to the headunit). in fact, i can see the ipod cable starting at the gear shifter and then combining into a bigger cable behind the cigarette lighter, but i can't see the end of the ipod cable anywhere! i have no clue where the other end of that ipod cable is so that i can plug it into the T1808 headunit.
edit: nvm i found the other end and plugged it into the back of the headunit. it was taped up behind the HVAC. just need to find out the part number for the cable that runs from the gear shifter to the arm rest.
edit2: these are the three cables required:
PT546-21060: Head Unit --> Gear Shifter (~$60 from the dealer)
PT546-21061: Gear Shifter --> Arm Rest (~$80 from the dealer)
PT546-21062: Arm Rest --> iPod ($56 on TRD Sparks)
there's also a seller on ebay selling a SINGLE wire that replaces all three of these for only $70 with free shipping. the part number is SC12235: http://cgi.ebay.com/ebaymotors/Scion...QQcmdZViewItem
pjl52
Aug 13, 2015 02:38 PM
Wrencher
Jul 29, 2015 01:38 PM
semlin
Jul 29, 2015 02:07 AM
Mica09
Jul 25, 2015 05:28 PM
Bish80
Jul 24, 2015 02:02 AM
