Knukonceptz konFUSED KNF-23 (anyone used it?)
I just received this item today and it uses a compression type connection that frankly Im not impressed with at all.
http://www.knukonceptz.com/assets/Tech/knfhowto.pdf
Unless I have just missed something completely, the connection is not at all tight. I used the approprate ring for the cable I have and after tightening down I noticed the cable moved around a bit. I pulled on the cable with a little force and was able to pull it out of the fitting.
If anyone has used this and knows better let me know, otherwise I do not recommend this product at all.
On a side note... My Polk SR124 DVC's and second Polk C500.1 arrived today. The SR124's are sweet. Unfortunately the break in period is something like 60 hours.
Both my roommate and I have ordered their amp kits from them and they make some good quality stuff based on my experience. Have you folded the wire around the fitting like in picture 3? I want to say that would make a difference if you haven't. Also, check the fold and make sure it is consistent around the entire egde.
Just a poor design IMO. It might actually be tight enough for what it does but Im basing it on my electrical background where a loose connection like this would just be a point for problems in the future.
If anyone has a GOOD 1 gauge set screw type distribution block that will accept ANL fuses and has three 4 gauge outputs Im willing to trade
Ok distribution block aside...
Im ordering wire right now and need to know what size to get for grounding. I planned on a distribution grounding block and was going to do 4 gauge from ground to block and 4 gauge out to amps but looking at some of these blocks it seems that 4 gauge in and 8 gauge out seems to be popular.
Will that be sufficient ???
One Polk C400.4 and two Polk C500.1.
Chatting with eD support now and they suggested 0 to ground and out from block with 4 so thats my ticket
Im really picking their brain
but at least I am going to actually order from them.
zarquonfrood
18
Jun 22, 2006 12:18 AM
zarquonfrood
16
May 31, 2006 03:43 PM
tbone587
Feb 1, 2005 06:54 PM
block, compression, current, distributino, distribution, fitting, fuse, gauge, grounding, high, holder, item, knf23, knukonceptz, konfused, pdf
