LED swap gone bad
Old Jun 4, 2007 | 07:22 PM
Luc1f3r's Avatar
Default LED swap gone bad
my tach needle doesnt work any more..
would one of you other modders please tell me what i need to do to fix my needle? when i idle it is at 0rmps. when i drive it NEVER gets over 1k. i can put it in park or N and rev it, but it wont go over 3k, ever... it worked fine before i shipped it off.... does it sound like Paul just didnt put the needle on right or what? please tell me its something simple and Paul didnt ruin my gauges!
thanks in advance guys!
(P.S. if you want you gauges swaped DONT use ledmods.net)
Old Jun 4, 2007 | 08:08 PM
KINGxOFxSKA's Avatar
Unique Scionikz
Default Re: LED swap gone bad
i think thats what everyone has agreeded on for a while, but not that many people listen. i dunno why.
Old Jun 4, 2007 | 08:12 PM
Luc1f3r's Avatar
i never saw the threads saying how bad he was until i had shipped. all i saw was a forum SPONSOR offering 40% off... who would think to second guess a sponsor?
Old Jun 4, 2007 | 08:13 PM
SuShIxFiSh's Avatar
1UP Crew
try taking off the needle and reputting it on maybe its pushed on to hard mine did that also and squal jsut took it off and placed it back on
Old Jun 4, 2007 | 09:27 PM
O5_TRD_tC's Avatar
Trung FTW!
Old Jun 4, 2007 | 09:29 PM
Garage1217's Avatar
Pm'ed ya, you should be set. If you need further help will provide my number via PM.
Old Jun 4, 2007 | 09:31 PM
Luc1f3r's Avatar
thank you sir, ill be in touch about teh wheel controls.
Old Jun 4, 2007 | 09:52 PM
engifineer's Avatar
Answered as well in the ledmods.net thread. Jeremy will take good care of you on the wheel controls as well. Still baffles me that someone does a swap and doesnt do a simple look and check to make sure the needle is on correctly....
If you fix that and the tach still doesnt work, let us know. I can try to give you some things to check based on the circuit mapping I have done so far on the gauge components.
Old Jun 4, 2007 | 09:59 PM
SquallLHeart's Avatar
^^ engifineer FTW!
remember folks... my number is located in my sig for anyone who needs some help. i'll help as best as i can.
also.... if it is indeed not because of the needle being pushed in too far... i have one major suspect as far as what happened... just because of another incident i've had to fix myself.
Old Jun 4, 2007 | 10:05 PM
Garage1217's Avatar
I am gonna prank you every night at 2am, 3am, 4am, hahaha j/k
Old Jun 4, 2007 | 10:07 PM
Luc1f3r's Avatar
you guys are great, im sorry i let the 40% off sucker me in!
Old Jun 4, 2007 | 11:52 PM
i added a little tidbit to my last post if you didn't see.
if it's not the needle being in too far.. i have another suspicion on what it could be.
Old Jun 5, 2007 | 12:00 AM
b_wet's Avatar
what could it be?? i think all of us LED swappers have had at least one bad needle experience. its always good to have an extra cluster around, i once had to replace the whole needle motor thing because it just would not work and it would make a wierd ticking noise.
Old Jun 5, 2007 | 12:06 AM
it all has to do with clean soldering work, and cleaning everything after you're done. (not that i'm accusing anyone of it..... hmm....)
but miscellaneous pieces of solder crap that lay floating around can create shorts or jump certain components and actually cause the motor or other things to malfunction.
i had an individual with a faulty speedometer come in that had issues with the needle and motor moving... after opening it up and just visually analyzing it... i somehow spotted the smallest damn piece of solder that was stuck on one of the capacitors which was creating a short.
after removing it... speedo worked again perfectly.
Old Jun 5, 2007 | 03:11 AM
Luc1f3r's Avatar
so yes, like everyone thought, i pulled the needle too far... now what?
i tried riding around for a few minutes without the needle on there, then putting it on pointing were i thought it should be, and that worked for a second or two, then when it dropped to idle it would go past the 0.... so what do i do now?
Old Jun 5, 2007 | 03:34 AM
Luc1f3r's Avatar
also, on start up, the tach goes all the way, with the other gauges, so i guess that means the motor works, correct? its just a matter of getting the needle on there correct...
Old Jun 5, 2007 | 04:46 AM
falkor's Avatar
Glad I waited . ledmods was the place i ALMOST went with . Whew !! Jeremy took very good care of me .
Old Jun 5, 2007 | 05:16 AM
Luc1f3r's Avatar
is this what yall are gona tell me to do next?
15.) After 5-10 minutes, the polish should be dry and you can start putting the needles back in. Line up the needle pin with the housing and push down slightly, but not all the way in. Turn the needle counter-clockwise (for the gas gauge, turn the needle clockwise) until you feel it snag. That's the stop point. Pull the needle housing up and place it at your marking on the gauge to align the needle properly. Once it's all lined up push down the housing until its almost flush with the gauge. (Don't push too hard or the housing will be too close to the face of the gauge and will end up rubbing against it and the needle won't respond as quickly as usual. Also try to push the housing in as straight as possible or the housing will spiral around the pin and you'll not be perfectly on the stop point.)
if so, then what am i doing wrong? i tried it twice but it still doesnt seem right. start up it goes all the way and back. it stops at 0 but some times it goes below and it seems like it idles a lot lower then it used to. and doesnt accelerate as it used to...
Old Jun 5, 2007 | 07:27 AM
theunclesam's Avatar
I had this same problem with my speedo after doing my own gauges. Turns out I had touched one of the small capacitors (small grey boxy looking things on the board) with my soldering iron while working. It was enough to cause it to disconnect from the board. My speedo would jump around and do all kinds of crazy stuff.
Anyways, long story short, I ended up using a multimeter to trace the circuit path and find the offending capacitor. I'm sure Jeremy remembers my phone calls...haha.
Old Jun 5, 2007 | 01:34 PM
Luc1f3r's Avatar
hmm, ok. so after doing the proper steps, the proper way (i believe) heres what i got:
Start up sweep: works fine.
at city speeds (normal roads, stop and go traffic) it seems like it works fine
at hwy speeds (constant 60-70mph without major change) it drops to 0 and doesnt move.
at city speeds the idle is around 300-400rpms
come to a stop after hwy speeds its at 0 and stays there till moving again.
i can put it in neutral and it plays around fine and doesnt seem to stick or anything...
