Manual different than diagram for fuses?
Old Dec 2, 2007 | 11:22 AM
ahloung's Avatar
Default Manual different than diagram for fuses?
i read some posts about blown cigarette lighter fuses and i read the manual and it says its number 34 but wen i look in the fuse box and the diagram... it says its number 23 and the fuse box under the steering wheel doesn't go past number 29... the number 23 fuse i took out is definitely blown though.. but the diagram on top of the fuse box does say the cigarette lighter fuse is 23 and the manual says 34... why are the numbers different?
Old Dec 2, 2007 | 09:43 PM
ahloung's Avatar
can someone please help
Old Dec 5, 2007 | 12:20 AM
PlayinWithFire's Avatar
what r u talking about? the interior fuse box goes up to 48... look at the chart then look up under the steering column... looking up (like your legs are out the door and your head is under with the top of your head towards the firewall) #48 is the top corner (25amp fuse) and then follow the chart.
Should be right on the bottom row right?
Old Dec 12, 2007 | 12:56 PM
rosedaleny806's Avatar
where is the fuse box under the steeering wheel i cant find it...=/ and if possivble do u know which fuse is the radio one under the steering wheel?
Old Dec 12, 2007 | 05:39 PM
lay on your back and stick your head down there... you will see it.
Old Dec 12, 2007 | 06:03 PM
found it thanx alot
Old Dec 12, 2007 | 06:04 PM
no problemo... just use the manual to find the right fuse...
aligatocodile
Apr 16, 2015 08:33 PM
GetSlideways
Scion xD Drivetrain & Power
Mar 16, 2015 11:30 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
brianmets5
Scion tC 2G ICE & Interior
Nov 22, 2014 10:38 PM
