More Stereo Drama
Old Jan 2, 2011 | 08:58 AM
2bsilver's Avatar
Default More Stereo Drama
Hey whats going on!
my question is i have a pioneer avicf7000bt and i hooked everything up correctly, matched wire for wire and im still not getting any power to the unit, i did the bench test by mixing the red and yellow wire to a battery and it turned on but once i put it in the car nothing seems to work any advice on what i should do?
i thought it might be fuse but im not to sure how i could have blown that if i disconnected the battery before i started the stereo install
ps the old stereo doesnt work when i tried hooking it back up either :\
Old Jan 2, 2011 | 03:39 PM
Murphys_Law's Avatar
fuse blown, check fuse box under dash
Old Jan 2, 2011 | 06:42 PM
2bsilver's Avatar
Kk thought so, it's the 7.5 one for acc if I'm correct?
Old Jan 2, 2011 | 10:09 PM
yup yup, cig lighter will be out too
Old Jan 4, 2011 | 06:28 AM
2bsilver's Avatar
so i fixed it haha it was the fuse but theres two things that are wrong now: the fuses keep blowing once i turn it up to a certain point so is it possible to put a 10 fuse into that slot and have it working fine or no? and my equalizer presets keep resetting -_-
Old Jan 4, 2011 | 03:01 PM
GQQSE13's Avatar
^^^do you have everything connected and grounded? it shouldn't trip any. and yea your presets will keep resetting because you're losing power.
Old Jan 4, 2011 | 04:53 PM
2bsilver's Avatar
Yup I double checked today and everything was connected correctly should I maybe use a 10 fuse to match the one on the stereo or would 7.5 be fine? Loosing power to the stereo so checking the constant and power wires when I get home then haha
Old Jan 4, 2011 | 07:24 PM
GQQSE13's Avatar
hmmm you can try 10 i'm not sure how much difference it will make on it. its just odd that not even your old one works
prescottn
Scion tC 2G ICE & Interior
Apr 26, 2016 01:14 AM
prescottn
Oct 8, 2015 05:31 PM
DJrepresent
Aug 12, 2015 06:37 PM
RokGoblin
Scion tC 1G ICE & Interior
Aug 11, 2015 05:24 PM
Bish80
Jul 24, 2015 02:02 AM
