need help!!!
Old Mar 20, 2006 | 03:22 PM
06trdtc06's Avatar
Default need help!!!
driving down the road last night i tryed to roll down my window and the auto on it will not work ? i dont know if there is a fuse to fix this or what ,and it was flashing the green light on it??
anybody else have this problem, let me know
only thing i can think of is that i took off the battery cables so i guess it had reset something? let me know please
Old Mar 20, 2006 | 03:26 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
if you disconnected the battery at all, you will have to reset it
easy way....roll the window all the way up, then hit the auto down button, should work
(usually does for me)
i kno someone on here has a fix, not sure if its same as mine
worked on mine and other tC's
Old Mar 20, 2006 | 03:48 PM
SCI_TC_GUY's Avatar
Just hold the switch in the up position for 3 seconds after the window is up.... may have to do the same for the sunroof (hold the switch closed for 3 seconds after it's closed)
Oh, and RTFM
Old Mar 20, 2006 | 04:19 PM
sIcKsCiOnS
DelMarVa
Scion Tuners
haha
i never hold it for 3secs, always works once i put it up...and hit the down button
its good to go
its same for sunroof
Old Mar 20, 2006 | 04:30 PM
leonDB's Avatar
Yeah it needs to be reset. Happens when you disconnect the negative.
Old Mar 20, 2006 | 07:56 PM
06trdtc06's Avatar
thanks to all of you guys. what would i do w/o you
all i had to do was just hold it up for like 3 sec. while the window was all the way up, and then it works
thank you all again
