Need help with fog relay
so i picked up these fogs around a local car store, it worked great for a while then out of no where it stopped working im assuming its the relay- the relay part number wus Yl-388-s and i ahve been looking for it everywhere but no luck'
would another relay work, if so would a
Hella H41010001 Dual 87 40 Amp SPST Mini Relay with Bracket
i am about to out hids in but i cant until i figure out this probelm, anyone run into this?
Maybe check out the control side on the parking light circuit at the fog relay. Usually you can verify a ground signal sent out to the relay when you turn your parking lights on. Use a polarity test light to check that.
ok so i checkd all the fuses including the inline fuse and the blue 15 fuse they are both in good shape... i only did it for a few minutes i was about to go through all the fuses but i dont see the point, to me i still beleive that it is the relay im jsut worried about ordering the wrong one plus i went to places around here and none of them have it which i dont understand ..so idk what else to do i bought new hids for it which sucks that i wont be able to use it until i fix this problem please help anyone
OpTicaL
Sep 16, 2015 10:25 AM
SJMiller
Sep 12, 2015 06:33 PM
