Need a lil help asap....trunk measurements
I don't have access to my tC right now. Would someone be kind enough to measure the dimensions on the trunk for me? Basically the width of the cargo area right behind the rear seats, and the height from the floor to where the privacy piece (hatch cover-up) goes. I just need to figure out how big of a box I can fit for subs.
Thanks, I appreciate it!!!!
I'm at work, so I can't really run outside and do this, but I can tell you that the Dual box that I have is 14.4"H x 30"W. It fits perfectly height wise, with the hatch being able to close and the privacy thing covering it. Width wise, there is still a good foot or so on either side, so I'm guessing if you want wider than that you'll still have room to fit. Hope that helps some...
i had a box 38" wide in my tc, you can go maybe another inch or two wide tops. but once you go over 38" wide then it will start to lay on the raised part of the floor where the struts mount.
as for the height 13.5" is the max you can go and keep it under the cargo cover. i'd do 13" just to be safe, especially if it will be deep enought where it'll hit where the cargo cover latches.
hopes this helps man.
P.S. i haven't seen ya around on the forums much lately.... where ya been?
thanks i appreciate it
ive been busy on ecoustics a bit. audiopulse subs have really taken off so ive been shipping out quite a few of those. ive been on CA and a few other places here and there. i havent been on as much as i'd like to though. i'll probably be around a bit more here in the coming weeks.
Josho760
Jun 2, 2015 03:31 AM
