Need a straight answer.
Alrighty then, I've been searching around the forums and around the net for some info but I haven't been able to find a straight answer, some places say yes some no, blah blah. I just want to know if this is compatible with my tC. I have the factory 6 cd changer in it, and the only thing I've changed audio wise is I have some(non-factory) subwoofers. I'm trying to get it so I can run my iPod or other media player running through the car stereo. and if this wont work, is there anything that will?
Edit: or if that will work but it's not the best, is there one you would recommend?
First off, the one they have pictured IS NOT the DF-TOY. That's the PA11-TOY and that's about $90 more. Also. that one pictured will charge your iPod through the dock connection on the bottom. The DF-TOY does not! (Unless you find RCA Y-Cables that have a dock connection on the other end.) The PA11-TOY comes with everything you need except the RCA cables. I used to have the PA11-TOY and it was great! Then I sold it to upgrade my HU. Here's a link that will answer some of your questions at the end of the DIY.
PA11-TOY Install
The install above will work for either Aux. Adapter. You should be ok with PA11-TOY. The DF-TOY would be alright also but you won't be able to charge your iPod. Your factory 6-Disc Changer ? is answered in the link.
PA11-TOY Install
fm tuner - fast cheapest ~$20 not the best sounding; interference
auxilary ports - ~$60 good sound
bluetooth - good sound, play on bluetooth enabled ~$80
youve got plenty of options go with the auxilary ports
im not trying to sound like an _______ but there are plenty of ppl here with ipods cant u just follow what they did? or is there like a different reason y u cant?
Thanks a lot Hyghgynx!
I decided to go with the DF-TOY and picked it up today. I installed just a little while ago but I can't get it to work for some reason. I've tried taking all the CDs out and putting them all in, but still I get nothing. I can't get any static or anything, it's like I didn't even put it in... If I understand correctly to access the aux input I press DISC twice. That doesn't do anything for me
I get no response whatsoever when I do that. I followed the instructions in the link you have me exactly as they were there. If I'm just being stupid I apologize. Any help would be greatly appreciated.
I don't see a switch anywhere on it, so either I'm blind or it's not there(I'm pretty sure it's not there)... I checked all my cables and unplugged everything and plugged it back in just to be sure. Turned the ipod on, turned on the radio and hit DISC twice and still I got nothing. When I have CDs in it just plays CDs as it normally would and when I don't have any CDs in it doesn't do anything at all
I didn't unplug the cables that were already in there on the back of the radio(which I guess are there for the antenna and stereo and such) could that have anything to do with it?
BlingSlade
Sep 5, 2015 08:52 AM
