Only HALF of the HEAT/AC works right?
So this is the issue that I've been having over the past six months.
It's Summertime, and I have a few more weeks to fix this problem before winter arrives again.
Can someone help?
Is it the blower motor......
Is it the resistor to the motor....
Is it a plastic rotating widget....
My feet freeze during this past winter on trips over twenty minutes.
I have not done any meter testing because I don't own a amp/volt tester, but I have looked at several threads and several videos. None have ONLY the top vent functioning perfectly well at all output levels (low-high) but not the bottom fan blowing out properly.
When I put my hand down near the feet area, I notice that heat works for a split second or less some of the time when I change the fan speed to different levels.
But ultimately cuts off to no air underneath the dash.
The top vents push out air/heat perfectly.
Any suggestions?
Can someone help?
Any suggestions?
