passenger side window button doesnt work from drivers side
Old Oct 20, 2006 | 12:45 PM
no-tec's Avatar
Default passenger side window button doesnt work from drivers side
The other night I took apart both the driver and passenger side molds to the door locks/window switch pieces, in order to paint them. I put them back together this morning and every button works on both sides except for the drivers side button that controls the passengers window.
Has anyone else ever ran into this problem before? Are both sides connected somehow and only 1 wire is malfunctioning? Like I said the passengers side window button still works just fine its just on the drivers side. Does anyone has any ideas on what else I could have done to mess something up? Np paint got into the wiring that I know of [maybe a chip perhaps fell off the underside?]
Thanks guys if ya can help.
Old Oct 20, 2006 | 01:05 PM
no-tec's Avatar
Double post with picture taking sunglare goodness
Old Oct 20, 2006 | 02:04 PM
grant13's Avatar
this has happened to me before...i was freaking out when it happened the first time. try holding the button up....i don't remeber exactly how it goes back but don't stress it goes back
Old Oct 20, 2006 | 02:05 PM
L8u8k8e8's Avatar
Is the led blinking on the button, or is it solid?
Old Oct 20, 2006 | 02:13 PM
no-tec's Avatar
Okay yes, I just checked, the LED on the drivers side drivers window is blinking [the one on the left] What does that mean?
Also, if I push the passengers side window button to make the window go down or up, then press the drivers passengers side windw button the opposite direction , it still counteracts it and will stop the motion of the window [as it should]
So I know it works just... not properly.
Madzozs's Avatar
Did you try playing with the window lock button? Maybe you need somehow twisted something around and now need to have that button down to control the passenger side.
Old Oct 20, 2006 | 02:15 PM
no-tec's Avatar
yeah that was my first hunch as well. I unplugged the wiring and plugged it back in with the lock button pressed in, and not pressed in. Neither fixed it.
Also, I held the button up / held it down for maybe 10 seconds [as suggested above] but nothing seemed to kick it back into working order.
Old Oct 20, 2006 | 02:20 PM
L8u8k8e8's Avatar
The blinking light just means that it lost power and the auto setting is not set right
The Scion FAQ
That will link you to how to reset the window, keep trying it until the light goes solid.
That should fix it
Old Oct 20, 2006 | 02:24 PM
no-tec's Avatar
You're pretty much the greatest person ever. Thank you very much sir, I will try this during lunch.
Old Oct 20, 2006 | 02:30 PM
L8u8k8e8's Avatar
Just let me know if it works
Old Oct 20, 2006 | 03:23 PM
no-tec's Avatar
Wow I didn't think it would actually work but it did. Thank you so much, I really appreciate it!
Old Oct 20, 2006 | 04:13 PM
L8u8k8e8's Avatar
Anytime
Old Oct 20, 2006 | 04:38 PM
mandos's Avatar
Locked.
Please search or read the manual next time.
Yeah, it's in the manual.
Please don't take that the wrong way, but this has been posted about a billion times.
And the first thing that I did the first time I took my car apart was look in the manual to see what was happening, and it explains how to go through the reset procedure....it really is there for a reason
DAHOZZMAN
Dec 16, 2014 06:48 AM
minter66
Dec 15, 2014 01:45 PM
jpn6438
Dec 12, 2014 08:09 PM
boxzila
43
Jan 31, 2004 05:57 AM
iglooxb
Nov 6, 2003 05:42 AM
