Problem! Shift gears letters will not light up
Old Jul 21, 2008 | 11:53 PM
infasquad's Avatar
Default Problem! Shift gears letters will not light up
Hi, I recently disassembled my radio unit to replace my cd player. Everything went smoothly and I installed the new unit, but when I drove at night, I notice the Letters, (D, R, 3, L) located on the shifting gear, does not illuminate. Does anyone know what happened? Did I miss a fuse or forgot a plug? Please help, it's greatly appreciated bros.
Old Jul 22, 2008 | 12:57 AM
ExpresScion's Avatar
I would first check to make sure that the bulb isn't bad. I don't think any connections you would have unplugged for the radio would have affected that.
Old Jul 22, 2008 | 04:31 AM
infasquad's Avatar
which fuse do I check? the instrumental fuse box is rather confusing, I don't know what fuse it goes under as.
Old Jul 22, 2008 | 06:56 AM
krazyscion's Avatar
i don't think its a fuse...if u blew the fuse for the interior lights, none of the lights would come on....
i think its the bulb just check out the bulb...
Old Jul 22, 2008 | 06:58 AM
youngflyer's Avatar
solution....get a manual trans lol jkjk
Old Jul 22, 2008 | 11:23 PM
superwhiteTC20's Avatar
you probably knocked the bulb loose and now you just aren't getting the same lighting as you were. take off your shift plate and find the bulb. it attaches in a certain spot to shoot down and illuminate the whole thing.
hope that helps
Old Jul 23, 2008 | 01:35 AM
infasquad's Avatar
I went to the dealership today, they said it's not the fuse, it could be the bulb that needs to be replaced. When I was installing the replacement cd, I disconnected the battery from the car, so I "THINK" it might of blew the bulb. Does anyone know or can post some DIY instructions on how to replace the bulb under the drive selector indicator?
I took a picture of it, http://farm4.static.flickr.com/3220/...f9c0a074_o.jpg
Thanks guys, I really need your help again..
Old Jul 23, 2008 | 02:18 AM
pull out the middle console and remove your shifter and hvac unit. Grab your shift plate and pull straight up on it. it will pop right off and you will see the bulb connected to it. Thats it. PM me if you have questions or need some pictures.
Drew
Old Jul 23, 2008 | 02:34 AM
infasquad's Avatar
Do I first of all, have to disconnect my car battery to do this? I found a page that someone posted.. What you guys think? http://www.scikotics.com/forums/showthread.php?t=18404
Old Jul 23, 2008 | 02:42 AM
I didn't...i'm pretty sure you'll be ok...could be wrong but it didn't kill me
Old Jul 23, 2008 | 04:20 AM
infasquad's Avatar
Hmm, i just hate it when i disc the battery, everything resets, like my passenger windows won't work, and that's when the bulb went out on the console.. Does it matter if the batter is still connected?
Old Jul 23, 2008 | 05:29 AM
SquallLHeart's Avatar
you don't need to disconnect the battery... and you don't need to pop out the shift release override either... ( just stick your key in)
and the screwdriver thing to pry it apart? you don't need that as well.. it just pops out if you pull. outwards.
Old Jul 23, 2008 | 06:38 AM
BZinn1's Avatar
the bulb gets loose pretty easy when you take out the center piece to remove the waterfall.........mine did the same thing.......my cubby light is still off......hate to take it back apart again to put it back in.......gonna try to reach it from the back......
But yep just remove the lower part of the console and pull up on the shift area cover and yo will see the bulb.......
eric_m
52
Jan 17, 2019 05:50 AM
gularti
Dec 4, 2014 01:21 PM
iglooxb
15
Jul 25, 2004 06:18 AM
KingLou
29
Nov 20, 2003 03:58 AM
scionaraxb
Nov 7, 2003 08:16 PM
