quick help
i need ur help asap
ok, im getting my interior painted later today.
i removed all my pieces, but im having trouble taking off the steering wheel controls.
yes, i did search.
i kno that u have to remove the 2 screws on the side, but i dont kno what tool to use to take them out.
can someone please tell me
and im not to familiar with screws so please be specific. the proper size would help to.
and if u can post a pic, that would be even better.
thanx
yes, i did search.
thanx
t30 sized torx head screws. Your going to have to twist HARD. they're in there really tight from the factory.
they dont completly come out, they kinda loosen alot and just hang there. once to that point, pul the horn/airbag towards you gently.
now that the inside of the steering wheel is exposed, you'll see a small phillips head screw holding down each plastic piece. undo the phillips and pull the pieces towards you and they'll pop out.
https://www.scionlife.com/forums/viewtopic.php?t=91321
Originally Posted by spECIal
alrite. i'll try to get it off on my lunch break
o, should i disconnect the battery so the airbag doesnt come out.
or will it be fine with the battery connected?
