Replacing speakers + questions
Old Jul 24, 2007 | 12:21 AM
Moonkei's Avatar
Default Replacing speakers + questions
My stock speaker on the right passenger side has been having weird rattling issues lately....so I opened everything up a few mins ago, and yep...the noise is only coming from the speaker itself.
Can anyone recommend a set to replace the stock? I'm not looking for anything pricey, just something that sounds as good as the stock.
Also, would this be a easy install? As in just removing the stock wire currently plugged in to the stock speaker?
Old Jul 24, 2007 | 01:22 AM
Dr_Isotope's Avatar
The best deal out there (right now). Sound great on an OEM HU, will sound great if you amp them down the line.
Old Jul 24, 2007 | 02:47 AM
Moonkei's Avatar
Looks like a good deal, I don't know too much about how to connect this. Is it as simple as disconnecting the stock and plugging it into the new set?
Old Jul 24, 2007 | 02:59 AM
mattieg's Avatar
eh not so much. If you are gonna get a component set like is shown above you will have to do a lot of cutting and adding speaker wire. You will use the stock speaker wire as the input to the crossover, then run speaker wire from the crossover to the woofer, then wire from the crossover to the tweeter. IF you get a coaxial you can buy a speaker plug for the stock speaker plus and then it would be a simple swap.
Old Jul 24, 2007 | 03:41 AM
kileil's Avatar
Damn Doc, thats a good price for Cliff Design components
Nice find
Old Jul 24, 2007 | 05:08 AM
ScionTcZ's Avatar
Check everytinng right on that audio circuit , make sure there is no broken wire or connection
Old Jul 24, 2007 | 06:59 AM
WAlterEgo's Avatar
if its rattling it could be something that its vibrating against. maybe something loose or some small debris in or around the speaker. is there a hole in the speaker? possibly blown?
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
torranosaurus
Jan 28, 2015 04:53 AM
lunchbx05
Dec 29, 2014 07:53 PM
rancur3p1c
Scion tC 1G ICE & Interior
Dec 21, 2014 09:23 PM
