Soldering my cluster
Ok. This has to be the most frustrating thing I've done in a while. Anyone on the SE region know how to get this done? I've got the HVAC and the Gauge Cluster LED's/Resistors. I'll gladly pay and even travel to you probably if you are in GA.
edit: I have now closed the circuit b/c i used too much solder on one little led spot. Now need a little vacuum like thing to suck it up. I got a bad feeling about to mess this whole damn thing up so if someone wants to give it a wack leme know.
I have the white warning LED's working fine. I haven't started on anything else but I did try to attempt the 2 resistors and 4 leds for fuel and temp. None of that works... In fact, neither does the speed or rpm led's. Any reason why the warning led's work and everything else doesnt?
Hey man I'm in valdosta and I can do this for you, as for them not working the simplest is that they are all not connecting the board, and the worse would be that you burnt the board. It depends on a lot of things. what year is your car?
gedster314
14
Nov 17, 2018 02:56 PM
