Space Between Gas & Brake Pedals
I "test drove" a tC today. I say "test drove" because the demo car was a manual and when I got in I wasn't too surprised to see that the gas and brake pedals were too close to each other. Considering I wear size 14 boots I barely had any room between the two and I could see myself pushing both pedals down by accident in an emergency situation. I did get to go for a drive, but I had the salesguy drive me around because I wasn't willing to have a problem with the pedals.
I did ask my salesguy if it was possible to have their shop give a little more clearance between the two pedals, but he came back and said they couldn't do that.
So my question is, do any of you know if it is possible to get more space between the two pedals without causing a problem? It's not an issue if I have to take it to a shop and get it done, but I'd like to know if I have this option.
I was planning on getting an automatic, but when I saw that the manual also has cruise control, I'd rather go with that.
What do ya'll think?
I hadn't even thought that it would be the same on the automatic. I assumed (uh oh) that since the auto didn't have the clutch it would widen the gap between the gas and brake.
Now it's really important to find out if I can fix this problem; even with an automatic I might have issues.
Nuts.
Nuts.
Yeah, I noticed this the other day myself. I had on dress shoes (with wide soles) in the car for the first time, and I definitely caught the brake everytime I pushed down on the gas.
A friend mentioned adjustable pedal sets, and I couldn't find anything on McGeorge's. Does anyone know of a good place to find something like that?
Unfortunately since it's still a new car, I don't think they will have those for the tC yet.
Also, in regards to shoewear, I have to wear boots for work, and even if I wore sneakers, I can still see the pedals being an issue, after all it's not simply big shoes, it is big feet!
It's close and it bothered me at first but you get used to it pretty quickly.
As for pedal sets, most of them are designed to be universal so it doesn't matter that the tC is new. The downside with those though is that unlike the Scion pedals, they will require more work and might require drilling in order to install.
If you really wanted to, you could take it to a custom shop and have them customize some pedals for you. For example, have the gas pedal mount on the left side and the width "grow" to the passenger side. That should clear a good inch or two.
No, still the same, let me try to draw lol
the "I" would be the bar/lever that holds the pedal
this would be stock
.....................................c b g
driver side footwell [I] [I] [I] middle of car
customized for more room
driver side footwell [I] [I] I[] middle of car
See how there is more space between brake (b) and gas (g)? Just make sure you take it to a good shop, you don't wan't it falling off when you're driving
Previous owner of my mr2 put aftermarket pedals and when I was driving it this summer, it just fell off, and I couldn't find the pin lol. So I have a metal plated clutch and brake, and a rubber/plastic gas pedal now.
this would be stock
I know what you're saying gt4dreams and I might have to do that. I'll keep an eye out for any adjustable pedal sets that should work with the tC.
Hmm. I'll have to go back to the dealer wearing my smallest pair of shoes and see if that makes any difference. Hopefully this won't be a deal breaker because I really, really like the tC.
I have size 10.5 feet, but I think the pedals aren't close enough together. I like the pedals to be more or less touching each other -- makes one foot manipulation of both mindless -- but then I grew up driving old european sports cars with crashboxes.
My favorite thing to do long ago was to go screaming through the mountains early evening, in the middle of nowhere, barefoot. I'd still do it all the time today except there aren't any mountains around here.
