Is the stock Pioneer radio in a 2005 tc Single DIN ?
Old Mar 3, 2012 | 03:24 AM
Sands's Avatar
Default Is the stock Pioneer radio in a 2005 tc Single DIN ?
Old Mar 3, 2012 | 03:27 AM
Erager09's Avatar
Pretty sure their atleast 1.5 din if not double din...my 09 is double din and im pretty sure its about the same size as the 05
Sent from my DROID3 using Tapatalk
Old Mar 3, 2012 | 04:08 AM
Sands's Avatar
I ask because it looks like its double DIN- but posts here indicate that installing a new Head Unit that's double DIN requires some bracket work drilling.
If the stock ones double DIN, then why the need to drill out the brackets to make it sit back far enough to allow the cover to close?
Old Mar 3, 2012 | 09:25 AM
gmc_113's Avatar
It's a double din size.
Old Mar 3, 2012 | 02:44 PM
TheMuffinMan00's Avatar
it is a double din size BUT it is actually wider than a regular double din. SO when tyou install an aftermarket radio you still need a kit that has about 1/4 of an inch of plastic on each side and spaces the brackets out far enough to still mount the radio.
The part about the door closing is because the aftermarket radios face sticks out further than the factory radio because the factory radios were "designed" to be used with that door. Aftermarket radios do not have to take that into consideration when they build their radios.
It all depends what aftermarket radio you go with as well. Some radios that I have found will still let the door close while others no matter how far you space it back its not going to close ( while still having it look normal with the door open aka not having a huge hole all the way around the radio )
Old Mar 3, 2012 | 10:58 PM
Sands's Avatar
Thank you: Erager09,gmc 113 and MuffinMan00.
Any one know of a good $200- $250 dollar radio that will fit and allow the the door to close?
TY
Old Mar 4, 2012 | 12:18 AM
Erager09's Avatar
could always check out crutchfield.com. im a fan of alpine and pioneer but not sure on specific models...
wiltonhall
Jun 23, 2025 10:09 PM
SloTC1
Apr 2, 2015 07:11 PM
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
BlueBox
36
Jan 27, 2004 05:53 PM
ScottsXBScion
Nov 25, 2003 10:30 PM
