stock radio removal
Old Sep 9, 2006 | 05:16 PM
jess14200's Avatar
Default stock radio removal
im trying to remove my stock radio to replace and am not quite sure how to get it out of the dash could somebody please give me a pointer so i dont destroy my car.
Old Sep 10, 2006 | 02:06 AM
L8u8k8e8's Avatar
You have to remove the entire covering in front of the head unit.
This is how I do it: First, you need to shift your car into neutral and apply the handbrake.
Then remove the piece that goes over the gear shift **** and contains the cigarette lighter, just pull on the sides until it comes loose, then lift over the shift ****, you can disconnect the cigarette lighter from the wire it connects to, but I just let it hang off to the side.
Then you need to close the front cover on the radio and pull the entire silver piece off, again, just pull at the sides, it will come but you have to use a little pressure. After that is off, disconnect the wiring clip on the back of that and remove it.
The stock radio is held in by two phillips head screws and two 10mm (I think that is the size) nuts, these hold the metal mounting brackets on the sides of the head unit.
Now you should be able to disconnect the head unit and put in your new one, make sure you have a wiring harness to hook up to the old wires, it will make it a lot easier.
Good luck.
*EDIT*
Oops, I just noticed the one Squall already answered, didnt even notice jess had made two threads. Oh, well... he has his answer one way or another.
Old Sep 10, 2006 | 06:09 AM
TheQuietThings's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=138454
clickclickw00t
Feb 18, 2015 08:57 PM
EvalEvan66
Jan 27, 2015 02:26 AM
EvalEvan66
Jan 16, 2015 08:34 PM
Dmscomp8892
Scion tC 2G ICE & Interior
Nov 22, 2014 02:55 AM
MaxPower
Oct 22, 2003 09:22 PM
