Subwoofers are barely hitting. Need Help
Okay, I have two 10 inch subs in the back of my tC with an amp. I just took the previous setup out of my old car and migrated it into the tC. The only thing that was different between the two was the fact that the tC stereo doe not have RCA outs in the back so i had to use a high end splitter. I looked at the wire charts posted around here and i also got a buddy of mine that works at circuit city to give me the wires i needed to splice into. So i did everything and had gotten everything hooked up.
I find that only my right sub is working and it is barely moving. I mean i turn the radio to 45 and it is still barely moving. It IS working though. The left however is standing still. If i switch up the RCA from right to left, then the left works and the right stops. If i unhook both of the RCA from the high end splitter and touch either to metal i get intereference from the correspoding subwoofer.
The only thing i am not CERTAIN on is that i have the remote wire in the correct place, but the amp does turn on. Can anybody help me out with this? Thanks for the time.
Exactly what wires are you tapping into?
What amp are you using?
Is it an amp with high level inputs or are you using an LOC and then have RCA's running to the back?
Let us know and we can help you out.
Hope this helps.
Originally Posted by mandos
You know...I think it was me....That sounds horribly familiar
That and I vaguely remember offerings of beer if I was in the area.
Thanks tons for the help again, mandos.
Anyway, Bogwraith4 if what I pointed out doesn't fix your problem, you can definitely trust mandos' suggestions: he was super helpful and was able to solve my problem with just a description of what was happening.
I have a Blaupunkt PA2200 and i have the high end converter that turns into RCA and the RCA runs to the back of the car and into my amp. My amp came with this high end converter so i assume that it works with it. I spliced into 4 wires into the back of the HU. It was the small square plug that has 5 wires in it. I spliced into the Brown, yellow, white and red. I have switched the positives and negatives back and forth testing different ways out and they sound the same. Right one works (barely) and left one doesnt move.
yeah i have no idea. Maybe i have the remote wire hooked up incorrectly or something (even if that has anything to do with anything) but i splced that one into the bigger big hook up in the back of the radio. it is the hookup on the far right side. I spliced it into the grey one. That i believe is the Ignition wire.
Other than that i have no idea what the problem is. I have been working on it for a while and have had no results. =/
ok i just switched my radio to the xA setting and it sounds better. Then when i was playing a Cd i turned on the SRT (i think that is what it is) and the bass on that right speaker was hitting like normal. But alas the left was still not moving at all.
I mean it has to be something with the LOC is what im boiling it down to. I'm tempted to just hook the left parts of the LOC into the right lines and just go mono with it. Or get a RCA splitter and split the right side coming out of the LOC because it seems to be the only side that is working.
Are there any adjustments on the LOC??? that may be where your problem.... the LOC is designed to alter the signal voltage going to the amp.... Instead of hi-level (speaker wire) you can get lo-level(RCA).... play with the settings on the LOC to see if that'll change anything
it is a tsunami LOC and it has 4 wires coming out one side (grey, grey/black, white, whilte/black) and on the other side it has two rca terminals build into the casing and two brownish colored wires that i currently am not using and i have no idea what they are for.
Oh...that one...we sell it.
The grey, grey/black, white, white/black are for the input speaker levels.
The RCA's on the other side are for the RCA...the two brownish wires...normally one is grey the other white to show which side is which in case you forgot after plugging in the wires.
i dont know about the left and right problems. But i just did the same thing, but i had it done be a sound shop. Make sure your SSP is on feel or hear. Neautral sends zero bass to the sub. yeah and xa or xb sound better with the sub.
Good luck with it.
Good luck with it.
yeah i dont know what exactly is the deal. I got the right one hitting normal i think, so i am just going to route the left input wires into the rear right speaker wires as well. I will have to settle without stereo subs but oh well. I just hope that it doesnt cut the power in half somehow and then get two really weak subs instead of one medium one. =/
thanks for help though.
..... I will have to settle without stereo subs but oh well. I just hope that it doesnt cut the power in half somehow and then get two really weak subs instead of one medium one. =/
i think i figured it out. Apparently the LOC that i was using has two gain ***** on them and I'm hoping that they were the cause of the problem. I was going to try that out today and hope that it works. =)
