Sunroof Malfunction
Old Dec 22, 2007 | 05:35 AM
ScottTc13's Avatar
Default Sunroof Malfunction
Anyone had a similar problem? Thankfully it is closed, but it does not do anything at all. I don't even know what fuse it would be. Though, I figure if it was a fuse that I would have other electrical malfunctions, but everything else is good. Any help is appreciated. Thanks!
Old Dec 22, 2007 | 05:38 AM
kidwolf908's Avatar
Have you recently disconnected your battery for any electrical work? Installing HU, amp, speakers, etc?
Old Dec 22, 2007 | 05:52 AM
colt27's Avatar
I had the same problem too when i installed my system. Reset the electrical by disconnecting the battery for a little bit. Then start the car and hold the sunroof button for like ten seconds or until it opens. That should fix it unless something else is wrong.
Old Dec 22, 2007 | 07:23 AM
SquallLHeart's Avatar
fuse #33... the S/ROOF
located in the interior fuse box.. it's a 20A fuse.. fyi.
disconnecting the battery will only cause the auto function to not work, which can be easily reset... but if it doesn't work at all... yeah.. check that fuse first.
Old Dec 23, 2007 | 07:23 PM
ScottTc13's Avatar
Yes I had disconnected the battery when I installed my supercharger. But I noticed that it was working after the install and then it seemed kinda unreliable, it was hesitating a bit when closing, and I remembered that I had opened it up all the way and it wasn't cooperating when trying to close it. I'll try all of your suggestions, it sounds like it could be a setup/ reset issue like with the windows. Thanks for the info!!!!!! I'll give it a shot.
Old Dec 23, 2007 | 07:25 PM
jaxtcracer's Avatar
is your tC still in warranty? if so, perhaps take it to a dealership if you can't figure it out on the forums? haha always be wary of taking it to the dealership but if all else fails, might as well.. good luck nonetheless
Old Dec 23, 2007 | 11:22 PM
ScottTc13's Avatar
Nope the warranty expired loooong ago. But holding the stupid button down for 10 seconds fixed it the problem. => It wasn't working at all, and now it is working just fine. Thanks!!
Prolific998
Scion tC 1G ICE & Interior
Apr 16, 2017 06:09 PM
BlingSlade
Oct 19, 2016 12:39 AM
volume315
Aug 29, 2015 01:31 PM
volume315
Aug 29, 2015 10:28 AM
daniinpitt
Apr 4, 2015 08:07 PM
