tC Waterfall...
Old Aug 24, 2007 | 09:15 PM
DjEzE's Avatar
Default tC Waterfall...
does anyone know or have pix on how to uninstall the waterfall on a tC? i sort of know how to do it but im afraid i might break it. so i would apreciate pix. thanks.
Old Aug 24, 2007 | 09:18 PM
aen's Avatar
aen
the dash?
Old Aug 24, 2007 | 09:21 PM
HR_Guy's Avatar
Build a dam at the top.
Old Aug 24, 2007 | 09:22 PM
SicktC06's Avatar
Yes, the Dash. the center Console is designed off a waterfall...
But you unscrew the shift **** and pull up on the silver pieces on the sides. Once you get that off, then you just gently pry the rest of it off. It is quite easy!
SicktC06's Avatar
Old Aug 24, 2007 | 09:23 PM
AKAvensis's Avatar
you have a waterfall? like mtv pimp my ride?
Old Aug 24, 2007 | 09:29 PM
Nick06tC's Avatar
No need to unscrew anything. Here is a link on how to do it. (I took off the shift **** not knowing it could stay on)
http://forums.scionzone.com/smf/index.php?topic=1296.0
Old Aug 24, 2007 | 09:34 PM
SicktC06's Avatar
You have to unscrew the Shift ****... Like I said...
Old Aug 24, 2007 | 09:41 PM
Nick06tC's Avatar
No you dont, those pictures were taken the first time I did it. I thought you had to. I will post a pic up with it not unscrewed if you would like.
Old Aug 24, 2007 | 09:46 PM
DjEzE's Avatar
wow you guys are something else. thanks Nick
Old Aug 24, 2007 | 09:47 PM
TeeCizzle's Avatar
It Literally just POPS right off!!!......
Old Aug 24, 2007 | 09:56 PM
SquallLHeart's Avatar
i'm agreeing with Nick.. no you don't.
Old Aug 24, 2007 | 10:19 PM
BZinn1's Avatar
Easy to do..........pop the passenger side of the console up and then the drivers......and give it a tug back and up.....un plug lighter and remove wire.......then at bottom of water fall grab it at both sides and pull out....the top is just slipped into a groove at the top and once you have bottom out lower it and remove harness to HVAC........reverse to put back in......
Old Aug 25, 2007 | 04:42 AM
engifineer's Avatar
You only need to pop the lower console loose, so you dont have to remove the shift ****.
Old Aug 25, 2007 | 12:21 PM
Nick06tC's Avatar
hmm, like I said...
Old Aug 25, 2007 | 02:31 PM
toeveryhour's Avatar
fight nice kiddies, lol.
Old Aug 25, 2007 | 04:37 PM
Hyghgynx's Avatar
All I do is throw the shifter into neutral. Like Nick has said, you don't need to remove it.
Old Aug 25, 2007 | 04:41 PM
tCtCtC's Avatar
so, why r we deciding if u need to remove the shift ****? i mean, it takes just 10 seconds to screw off
Old Aug 25, 2007 | 05:00 PM
Nick06tC's Avatar
I just made a big deal about proving it because there is so much MIS-information on this site and many other scion sites.
People ask for questions, expecting to get correct answers. Yes a simple removel of a shift **** is inconsequential, but the small wrong information needs to be corrected just like the large wrong information.
Not trying to knock the person who said you have to remove it. Thats not my goal. My goal is to get the correct information out there. If someone does not know the correct answer, do not post it.
On some projects, giving the wrong information could hurt someone, or break something, causing alot of money to be wasted.
Old Aug 25, 2007 | 05:28 PM
i know for me at least.. it takes a bit more effort than 10 seconds because of the shift **** i have...
so knowing that you don't have to put that extra effort in unnecessarily is good to know
