Trunk lid seal creates suction a I can’t open it – Solution?
Old Nov 6, 2013 | 04:59 AM
filippo's Avatar
Default Trunk lid seal creates suction a I can’t open it – Solution?
Hello everyone, sorry if this has been posted before.
Sometimes when it’s cold outside the trunk rubber seal/trim creates a suction seal and I can’t open my trunk. I have to push the trunk door down and keep unlocking my car. So far it has worked OK, but the rubber trim has been coming off lately. My dealer wants to replace the rubber lid/trim and is asking $300. That’s insane. The trim itself is well kept, not dry, so I just need to find a way to glue it down. Ideas?
I have a 2006 Scion tC.
Thanks
Old Nov 6, 2013 | 05:42 PM
HKSpeed's Avatar
I had a similar problem with the seal sticking to the trunk door (but the seal/trim didn't come off like your car). I fixed it by applying some WD40 on the seal. I sprayed it on to a rag and wiped the seal with it. That stopped the seal/trim from sticking to the hatch.
Old Nov 6, 2013 | 05:54 PM
filippo's Avatar
Good tip. I don't think it needs to be glued down, but as you said lubricating it won't allow it to stick. Thanks
Old Nov 8, 2013 | 12:05 PM
criminaltc's Avatar
This sounds like more of a latch issue. Do you have subwoofers or did the person before you have subwoofers at all? A lot of times, like I have done, people (smart people) will tighten the hatch/latch connection making the latch so the hatch is forced to pull down harder, allowing the hatch to refrain from rattling because that is where most of your rattle comes from, that latch/hatch connection. So with there being so much pressure, the hatch doesn't want to pop up so you have to relieve the pressure by pushing down as you say to take the tension off the hatch/latch allowing it to open. But just opening it won't work because the amount of pressure. The only reason I'm saying this is because you say that you "push down" which is exactly what would cause this. Also, this would cause this since your seal is popping off. It's being pinched causing so much suction that when the hatch comes up, it's drawn to coming with it. Otherwise, you said it happens when it's cold. Well moisture turns into ice and moisture loves to sit in those seals, hence why the seals are even there, and in turn the moisture turns into ice causing the hatch to be frozen to the seal. But like HKSpeed said, WD-40 clears that up and doesn't allow the moisture to turn into ice and be pesty. Don't spend any money on that seal. Get the OEM seal and adhesive, which can't cost that much, and do it yourself.
Old Nov 8, 2013 | 06:15 PM
filippo's Avatar
I don't have subwoofers. Agreed, I'll lube the trim and do that do the trick. I won't be using WD-40 though, I heard it's petroleum based and eventually the rubber and dry and crack. I'm going with a silicone based lubricant instead.
Thanks for the tip, criminaltc.
Old Nov 8, 2013 | 07:17 PM
criminaltc's Avatar
Cool, let us know how it goes and what you find.
Old Dec 21, 2013 | 04:45 PM
sciontc_mich's Avatar
late bump to this thread. try some silicone spray. as the rubber gets older it dries out and can stick to things, especially in the cold. Lubricate it and it will not stick.
just read your last post and you were going to try silicone as any petroleum based spray would degrade/eat away the rubber. sounds like you're on the right track now! good!
Old Jan 19, 2014 | 07:23 PM
95maxrider's Avatar
My friend was having a similar problem in her Ford Escape and my first thought was to apply some motor oil to the seals to keep them from sticking together. If the seal is coming up, I would think about putting some black silicone window/door caulk under it. I had to do this to my old BMW when the trunk seal wasn't sealing correctly.
Old Jan 21, 2014 | 03:13 AM
skatalite's Avatar
I had taken my vehicle to toyota a while back for an unrelated issue but I mentioned to them that my trunk had also been sticking. He literally looked at me and said "put PAM on it" (the non stick stuff you cook with..) I did that and it hasn't stuck since.
Old Apr 11, 2014 | 11:44 PM
psturm's Avatar
Hit the gym hard as a mother then come back with a pump and lift it. Problem solved guaranteed!
k1114
43
Mar 1, 2023 03:08 AM
evolving_machine
Jan 13, 2015 08:04 PM
BlueBox
14
Jan 15, 2004 01:08 PM
