what do u guys think of this?
ive been looking and pricing audio stuff and i was wondering how this set up would sound. any input would be great, im a noob when it comes to subs and amps. i want the sound and feel of an 800 watt 12 inch sub but at half that power or less because idont wanna buy a cap... anyways tell me if this will get me close to what i want.
amp
http://www.cardomain.com/item/KENKAC6202
sub-
http://www.cardomain.com/item/KIC05C124
box or something in the neberhood -
http://www.cardomain.com/item/RTE31412
wiring-
http://www.cardomain.com/item/STRPS08B
well there it is tell me what u guys think...
amp
sub-
wiring-
1) If you want the sound of a single 12 with an 800 watt amp, then that's what you need to buy....
2)capacitors are widely mis-used by people thinking it will help with dimming lights... dimming lights are caused by voltage drops and a capacitor isn't going to be able to sustain any more voltage than the stock setup (if it does, it will only be for a few milliseconds)
3) don't buy ANY pre-fabricated ported box unless it's built and tuned to your specific subwoofers thiele/small parameters
4) What budget TOTAL (and for what equipment) are you looking at? I'm 100% positive all of us can help you make a better decision...
I'm not trying to be rude at all, but ask as many questions as needed for you to help yourself understand different concepts and in's/out's of car audio...
Edit: BTW, my tC handles 800 watts with no dimming.... chris(mandos)'s tC has had 1200 watts with no issues.... don't be afraid to get what you want...
Get Elemental Design 13kv2/nine.2 (12"/400w) package deal $289. Or 13kv2/nine.2x (600w) $331. Free shipping/3 year transferable warranty.
Build your own box, use the design proggie @edesignaudio.com.
I have a nine.2x and nine.4 in a Scion xB. I think an 80w alt. Handles it just fine. SCI_TC_GUY is correct. NO CAPS needed!
Elemental Design 13Kv.2 Dual 2 ohm - $125 shipped
http://edesignaudio.com/product.php?...pid=19&cur=USD
Hifonics 600x1 @ 1ohm amp - $130 + shipping
http://www.woofersetc.com/index.cfm?...roduct_ID=3373
this box single 12" ported 30Hz tune (PM me if you need cut list) http://www.edesignaudio.com/presetbo...gle_vented.gif
Caps aren't a gimmick if they're used correctly... they're supposed to be used for transient peaks at normal listening levels... if your lights dim when you crank the hell out of it, then that's a problem with voltage supply meaning the best remedies are: Big3 upgrade, new battery, new/rewound alternator in that order
I'm running 2 Elemental Design's Eu-700's (6.5") in a 30Hz ported box and they pound really nicely... you'll be a LOT happier with the sound/performance with eD's 13Kv.2 rather than the kicker comp...
here's a vid of the 6.5" subs I have (not my subs in these vids - just same as I have)
http://vincentroberts.com/ED72.WMV
http://www.edesignaudio.com/video/700video.wmv
depending on which amp and which sub configuration...
If you get the Hifonics amp I listed, you'll need a dual 2 ohm sub wired in parallel to get 1ohm mono at the amp...
If you get the Elemental Designs nine.2 amp with the 13Kv.2 sub, you'll still need a dual 2 ohm sub, but you'll have to wire it in series to get a 4ohm mono load
a sealed box will have a little tighter and more level sound but the ported box will be louder... I personally love the sound of ported boxes... and they're more fun to build..
about the middle of this page:
http://edesignaudio.com/product.php?...ckages&cur=USD
you'll see the package deal for 1 13Kv.2 and a nine.2 for $289... I'd go this route just because having matching brands looks better!!
so i have to bridge the amp then at the sub connect the first set of terminals toe the amp and then with the seconds set of terminals i connect the positive to the negitive... got it. so that covers subs amps and wiring. and i wont need a cap. so teh box... any one got instructions for a tuned box i think im gonnan go ported
well.... you've almost got it.... connect the + and - from the bridged amp to the + on one set of terminals and the - on the other set of terminals.... then connect the remaining + and - together.... with a dual 2 ohm sub, that will give you a 4 ohm mono load at the amp
this box is single 12" ported 30Hz tune (PM me if you need cut list) http://www.edesignaudio.com/presetbo...gle_vented.gif
Originally Posted by SCI_TC_GUY
Caps aren't a gimmick if they're used correctly... they're supposed to be used for transient peaks at normal listening levels... if your lights dim when you crank the hell out of it, then that's a problem with voltage supply meaning the best remedies are: Big3 upgrade, new battery, new/rewound alternator in thhat order
^^ not quite.... not a big bass hit... small transient spikes are where a cap comes in use... basically never...
The box I posted is an eD box tuned to the thiele/small parameters of the eD 13Kv.2
