Where to ground amp and run power wires?
Old Sep 25, 2007 | 08:18 AM
2005tcOwner's Avatar
Default Where to ground amp and run power wires?
Hi all,
I have done wiring for my old 98 corolla and 05 Matrix but I'm stumped as to where to ground my amp in the trunk. I don't see any readily available bolts on the body. Suggestions?
Where did you put your ground wire in the trunk? I always use a wire brush attachment on a drill to remove the paint for proper ground so it has to be easily accessible for a drill.
Also I was thinking about running my 4ga. power wire through the grommet but that is soo high and hard to reach. I was thinking about drilling through the firewall and putting a grommet. You think there is enough room in that factory grommet on the driver's side for a 4ga. wire?
Drilling the firewall easier? I'll post my setup once it's done.
I look forward to your responses and thanks in advance.
Old Sep 25, 2007 | 01:18 PM
nebster's Avatar
if you take out some more bolts you'll find plenty. there is always the shock tower bolts or the rear seat bolts. just make sure to dremel off any paint that was on them
Old Sep 25, 2007 | 02:56 PM
exige's Avatar
i used the rear seat bolts...works fine for me.
Old Sep 25, 2007 | 03:07 PM
Keeshwah's Avatar
Originally Posted by rocketgyrl
It's better to have a longer ground cable that works, than a shorter noisy one... I specifically said frame and stainless steel screw for a reason. All the locations you've tried use "rated hardware" ( usually grade 8 ), and while they're stronger than normal screws, they contain a high concentration of zinc, which isn't a very good conductor. Car manufacturers often use Loctite in these locations that would further reduce conductivity.
Again - find the frame. Sand it down. Stainless steel screws FTW.
There are 2 layers of sheet metal in the hatch and you can pretty much drill a hole wherever. Just double check before you do.
Old Sep 25, 2007 | 03:47 PM
nebster's Avatar
tc = unibody = no frame
Old Sep 25, 2007 | 04:29 PM
GammaTNT's Avatar
Here is where i ground the amp
Old Sep 25, 2007 | 05:55 PM
Keeshwah's Avatar
I was referring to the rated hardware part.
Old Sep 25, 2007 | 07:37 PM
nebster's Avatar
stainless screws? meh
use bolts. much better than screws = more contact area = more area for current to flow.
Old Sep 27, 2007 | 04:51 AM
Thanks tC peeps. I'm also looking at Mandos's "How to gut a tC. https://www.scionlife.com/forums/viewtopic.php?t=60981
Hard to force the 4ga. wire though the gromet on the driver's side? I'm planning on forcing it out to the engine cabin from the inside cabin.
Old Sep 27, 2007 | 05:18 AM
exige's Avatar
lol dude i stuffed 0 awg through there. you gotta open it up with scissors....it'll take some time and effort, but it'll go. took me about 30 min to get 0 awg through.
Old Sep 27, 2007 | 12:17 PM
nebster's Avatar
i know chris (mandos) has 3 runs of 0 gauge through there. you can fit some 4 gauge
Old Sep 27, 2007 | 12:51 PM
Keeshwah's Avatar
wow, 3? why?
Old Sep 27, 2007 | 01:00 PM
nebster's Avatar
because 2 for the power (he planned on having 3 nine.1's i think) and one for ground. The best ground is the negative of the battery so he wanted the cleanest ground he could possibly find.
Old Sep 27, 2007 | 02:36 PM
Keeshwah's Avatar
badass
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
randode
44
Jun 29, 2004 04:19 PM
vpkb
12
Oct 8, 2003 04:17 AM
