Will subs and amp work on stock headunit??
Hey i jus got some infinity subs and and amp so i needa know for sure can they work on the stock headunit and if it can does anyone have a link or somethin for how to install it
you can deff do it because thats wut i have for know ive had it for like 2 years now i have a indash screen but you can deff do it my buddy owns a system shop and he put in a module to buy pass something and it works
Look for a line out converter. It takes the speaker outputs and converts them to RCA outputs. I'd recommend installing it behind the headunit so if you do ever switch to an aftermarket hu, the RCAs will already be back there.
Search around on this site and you will find lots of information on this.
Go to this site and buy this add-n-amp harness kit connector thing. It will plug into your stock HU and then give you RCA outputs for your sub. There is even a place on there to put you rremote wiring to make it even easier. It costs about $40 and I recommend the rear speaker harness because you can use the front & rear setting to adjust the bass and you wouldn't want to drown out the front.
http://www.yoursciontc.com/forums/in...showtopic=5506
Let me know if you have more questions...
ok thanks guys yea i jus mainly wanted to know if i hadda buy anything to make the stockhead unit able to wire subs and amp, and needed to know if the stock headunit already had the rca outputs but guess not
And, Scion pride themselves on selling a car line that is intended for modification, but why in the hell would they have Pioneer make a HU w/o RCA's? Anyways, I agree w/ elecTriC, the sound quality changes completely with a good HU. But, my girl wants to keep the warranty as long as possible, so I have to be careful what I do, and that means no new HU.
Oh well... At least I got to install subs and an amp.
for my setup, i used an RCA line-out converter and tapped into my rear speaker wires for my amp signal. i think it sounds pretty darn good. im sure it'd sound better with an aftermarket HU, but i did the install right, took my time, adjusted settings, and its really nice. if you're running the stock HU, i find that these settings are the best for general listening:
Treble: 5
Bass: 0
Front/Rear Balance: R1
HU Mode: tC
after that, you just tweak your amp settings (filtering, etc.) and you're good to go. i have a remote gain **** that i mounted next to my driver seat, so if i need to turn up my sub, i just turn the ****.
Treble: 5
Bass: 0
HU Mode: tC
Anybody try this yet: JL Audio CleanSweep
Looks to be a good solution for those wanting to keep the stock headunit and get aftermarket headunit sound.
minter66
Dec 15, 2014 01:45 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
crocker
Dec 2, 2014 03:44 AM
