05 tC Drive Cycle - Catalytic Not Ready
I was looking for blown fuses and might have pulled the ECU fuse a month ago.
Since then, I tried to smog my car recently. However I failed the sensor test since my Catalytic sensor kept coming up Not Ready on the OBD2. The only thing i was told was drive it more.
Since then I have put about 400-500 miles on my car, and with my own OBD2 reader the cat still says "Not Ready". I have read online that there are specific drive conditions that must be met in order to pass the cat sensor.
I've tried cold starting the car and letting it idle for 5 minutes.
Drive 60mph for several miles
Drive in city traffic
Does anyone have any suggestions?
Can't say for sure but here are my thoughts:
Is the catalyst the only thing that is not showing as ready? What about the other sensors? If it's just the catalyst, that suggests the secondary O2 sensor, wiring or the converter itself. If it's more than that, then there's either an issue with the constant power source for the ECM or the a problem with the ECM itself.
how old is your battery? have you replaced it recently?
I had this issue with mine for a while. the had to do their drive cycle thing specific to get it to pass, it was a whole nightmare that took a while to figure out.
the constant power issue bbsciontc mentioned may be the problem, after I replaced the battery, I have not had the issue again.
there were no other issues or test showing that the battery was actually bad or anything, I just decided to replace the battery.
Thanks so much guys for the responses.
@bbsciontc
Something strange just happened, i checked the obd2 scanner and now EVAP & CAT both show "not ready". Is this indicative of the ECM not getting proper power? And could I be experiencing this even though engine and other cabin electronics/amp/sub start up fine?
@gjpjr84
The battery has been on the car since at least 2010 (possibly earlier). Were you able to pass the sensor after doing the specific drive cycle before replacing the battery? Or only after replacing the battery did it become ready?
sorry for all the questions, i just want to avoid spending unnecessary money.
@bbsciontc
@gjpjr84
Here is a diagram of the ECM harness and pinouts. This is assuming you have a 2005-06. The newer ECMs are different and I don't have the diagram.
It may be possible that even though an ECM isn't getting constant battery power, it may be able to function once the ignition is turned, especially since the main power source for the ECM is switched with the key cylinder.
With the ignition off, check that the "Always on" terminals are receiving battery voltage, a minimum of 9V, although you should definitely be higher than that. It's the first two indicated in the diagram. If that's good, then the ECM is getting voltage needed to retain memory. If not, there may be a fusable link that has busted for some odd reason.
Beyond that, you will have to troubleshoot on a step by step basis, starting with the secondary O2 sensor which is monitoring the catalyst. Unfortunately it's a process of elimination exercise. Not the most fun.
Would unplugging to check for voltage on the harness lead to wiping out its memory? I just want to make sure I don't undo any of my previous driving miles if driving it more really is the culprit.
Thanks again!
the dealership was eventually able to get it to show as ready by following a specific routine that I do not know the details of, and they just used the same routine whenever it needed inspection again.
their possible diagnosis was the same, of it not having constant power somehow, but as I said before, there was nothing wrong with my battery or wiring that they or I could find.
I had the issue until i decided to change my battery, I haven't had the problem again.
OBD2 is a strange animal. It has a series of things that it looks for to set readiness. Almost a checklist. What that means is that in some cases if a particular sensor is not setting as "ready" it may not proceed to set readiness on subsequent sensors. It depends which ones however. It is possible that the evap may being hanging up just because the catalyst isn't setting as ready.
If you pull the fuse, harness or battery, yes, you many reset the computer. I will tell you this though, I've been pulling mine almost every week trying to diagnose an issue I am having with an aftermarket computer. Each time I reset the ECU, all the readiness codes were set to ready in less than 100 miles and maybe 4 or 5 driving cycles. If all is working well, it really shouldn't take long. If its accessible enough and you have narrow probes on a multimeter, you should be able to test for voltage without unplugging the harnesses from the ECU (probe from the wire side of the harness)
Some people have different experiences with this, and it may be a function of the type of driving you need to do for each test. I do a good bit of highway, but a portion in bumper to bumper traffic so that would be considered city driving. Also, sometimes you need about a half full tank for the evap test to set. It will postpone the test if the tank is full or nearly empty.
Update! Before i got a chance to check the voltage to the ECU, I decided to take the car on a canyon drive near my house, round trip about 40 miles and cruise controlled it @ 50-52mph the whole way.
CAT sensor "READY" !! :D
Now onto the EVAP...
Good stuff! The evap should set on it's own now. Generally, the tank needs to be about 30-70% full, and sit overnight for about 8 hours or so. What happens is that after the car is fully cooled off, a pump turns on an pulls vacuum in the evaporative emissions system. It then verifies that the system can maintain vacuum (i.e. no leaks) and if all is well, it should set to ready. Give it a night or two and you should be set.
Having trouble getting the EVAP to set to ready. Been driving it the last few days with 10-12 hr cool-off periods. Also filled the gas twice only up to 3/4 full. Anybody have drive cycle suggestions?
I tried following this one i found online:
Toyota/Lexus OBD-II Drive Cycles | Car OBD Diagnostics, ECU Chip Tuning & Auto Repair Support
On step 5. I did let the car sit about 10 min on idle before turning it off, 50 minutes seems a bit extreme doesn't it?
Here's a better reference specific to this engine. All conditions must be met for the test to begin.
Also, check if there are any pending codes (do not reset or you will have to set the catalyst again). It is very common for these cars to have a gas cap leak, causing you to actually fail the evap test (small and/or gross leak detected). I changed my cap twice with oem, and none fit very well. An aftermarket replacement (Stant) cap fit much better and made my codes go away.
- The engine coolant temperature is between
4.4°C and 35°C (40°F and 95°F).
– The intake air temperature is between 4.4°C and
Interesting. Around that mileage I started getting evap codes. I recently replaced my gas cap gasket and downstream o2 sensor but I was getting codes for both. It sounds like the ECU is resetting before it can complete a drive cycle.
ptperson
Regional - Pacific Northwest
Feb 13, 2015 04:03 AM
rcflyer15
Dec 5, 2014 05:15 PM
ScionLife Editor
Nov 28, 2014 11:10 PM
