Car won't start, possible brake issue?
Old Feb 6, 2010 | 11:07 PM
keeganzero's Avatar
Unhappy Car won't start, possible brake issue?
So this morning I got up and decided I would go run some errands in my '05 tC but when I got in my car and attempted to start my car, something odd happend.
When I turn the key I get a really odd clicking noise and the car will not start, at all. The other odd thing is that my brake is completely pressed and is locked in that position, so if I do put it in neutral or drive the car will not roll one bit. I am completely paralyzed and I have no idea what to do. And to make things worse I have plans to drive up to Sacramento (currently in LA) to see my girlfriend for valentines day so I need to get this fixed ASAP.
Any suggestions? I'd very much appreciate any help I can get right about now, very very very desperate
Old Feb 6, 2010 | 11:13 PM
RoboCop's Avatar
Sounds like you need a new battery. Same thing happened to me. Jump the battery if you can.
GQQSE13's Avatar
the clicking sound means dead battery
Old Feb 6, 2010 | 11:16 PM
keeganzero's Avatar
Really? The radio turns on and I can turn on my lights, turn signals, etc.
Old Feb 6, 2010 | 11:27 PM
DJ08tC's Avatar
it is a dead battery, it may have enough power for that but doesnt have enough to turn the car over.
Old Feb 6, 2010 | 11:30 PM
keeganzero's Avatar
Ok, thanks guys. I'll try jumping it and see if that fixes it.
Old Feb 6, 2010 | 11:50 PM
Jan06xB's Avatar
If your brake pedal is down the brake lights should be on too and that will kill the battery - charge it up and you maybe ok. The clicking sound is not enough juice to turn the starter motor over and the relay clicking in and out without enough power. Check your brake fluid level under the hood too!
Old Feb 7, 2010 | 12:57 AM
XIEmperorIX's Avatar
Check your brake master cylinder..if it was depressed all the way to the ground like that and not coming back up chances are it's done..
Old Feb 7, 2010 | 03:49 AM
jbae1221's Avatar
it depends.. if you heard a lot of clicks then it is most likely your battery if you heard just one loud click then it is your starter
Old Feb 7, 2010 | 01:03 PM
sw09's Avatar
get a big booster pack to jump the car, or hook up booster lines to a big truck and try jumping it.
if it doesnt work try tapping the starter with a rubber mallet while the car is cranked(make sure not to scratch the starter). (if you dont have a rubber mallet use a cloth to cover the started and tap it with something else, keep in mind its a tap, not wailing on it)
Old Feb 9, 2010 | 04:00 PM
keeganzero's Avatar
Did a jump, guess it was just the battery
I feel pretty dumb now, thanks guys for the help
Old Feb 9, 2010 | 08:13 PM
Check your brakes because the pedal should NEVER stick to the floor like you described under normal operation.
Old Feb 9, 2010 | 08:51 PM
keeganzero's Avatar
I did, brake fluid's good and the master cylinder is fine.
Old Feb 10, 2010 | 06:26 PM
Jan06xB's Avatar
Was it down to the floor or just really hard to press? If it was hard to press then you just lost the vacuum boost which can happen if you press the pedal a few times after the engine is shut off and is no big deal. If it happens all by itself then you have a vacuum leak and that needs to be checked before you loose your brakes for real even with the engine running.
Old Feb 10, 2010 | 08:05 PM
keeganzero's Avatar
I think it may have just been pressed a few times after it was off, no big deal
Old Feb 11, 2010 | 05:42 AM
p120ud213azn's Avatar
call AAA
Jordly221
Feb 13, 2019 05:29 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
cid_mcdp
Jan 5, 2015 02:45 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
bruceb25
Nov 23, 2014 04:52 AM
