E-Brake Light Comes On When Accelerating Hard!
Old Mar 3, 2008 | 01:02 AM
KillaSpiceTSW's Avatar
Default E-Brake Light Comes On When Accelerating Hard!
I dont know what the hell is happening to my TC, hopefully something minor. Anyways today after watching Nascar with my Old Man I left to go home and on the way back everytime I accelerated in 1st, 2nd and 3rd somewhat hard my E-Brake light just kept popping up out of no where. So I decided to stop my car and go up and down with the damn thing to make sure it wasnt stuck. Took off again and it kept doing it. Can any of you intelligent folks tell me what the hell is wrong with this car. Thanks alot.
Old Mar 3, 2008 | 01:07 AM
BrownDogg's Avatar
That happened to me awhile back. It means that your brake fluid is getting low. Check it and add some brake fluid and you should be good to go
Old Mar 3, 2008 | 01:10 AM
flintMicaTC's Avatar
i had the same thing going on with mine except brake fluid was at level. i had to replace the front brake pads. DEZOD's the place to go for extra fast shipping! i only waited 2 days!
Default Yes
Awww Poop intelligent people responding quickly. Gotta love America. Thank you very much kind sir. LOL. Enough of my bs speech. Thanks bro. Ill check it. God I hope thats what the hell it is.
Old Mar 3, 2008 | 01:12 AM
either that or your car might blow up, no biggie
Old Mar 3, 2008 | 01:13 AM
maximthegreat's Avatar
it could be brake fluid or time to replace brake pads, brake light is not only for e-brake but it is also to warn you about problems with your braking system
Old Mar 3, 2008 | 01:14 AM
SquallLHeart's Avatar
........ never just fill up your brake fluid...
if it's low.. it's probably low for a reason.......
check your brake pads FIRST.
cause... yea... the fluid can be low due to your brake pads..
Old Mar 3, 2008 | 01:26 AM
Default Hmmm
Fluid seems to look fine and the front brake pads look fine as well. Now im starting to worry.
^very well spoken
Old Mar 3, 2008 | 02:00 AM
unsungfate's Avatar
this happens to me also... except i've checked my fluid and its good... and i JUST changed my pads (front and back) and checked fluid after that and still good.... whats going on??? is the lever loose and on hard acceleration it lifts slightly up? like just enough to make the light come on? if not should i go to toyo and have themm look at it?
Old Mar 3, 2008 | 02:24 AM
Default IDK
I think were f@cked. My pads and fluid are good to. I dont know.
Old Mar 3, 2008 | 02:59 AM
t_urbo_C_harged's Avatar
x2... 9 times out of 10 fluid is low because of front or rear pads being worn or low...
how many miles do you have on your car? you may have a bad brake fluid level sensor but I doubt it sense it is only under acceleration... make sure it is up to the max mark, not the min mark but again don't fill it up, recheck your pads....
Old Mar 3, 2008 | 03:01 AM
maybe brake lines?
Old Mar 3, 2008 | 03:05 AM
unsungfate's Avatar
i got 45000 on my 06
Old Mar 3, 2008 | 04:43 AM
Originally Posted by maximthegreat
maybe brake lines?
they then wouldn't be able to brake well if one of the lines was leaking... and the fluid would be low...
I would maybe take it in just in case you have a code...
another quick check you can do is wiggle the e-brake slightly and see if the RBWL (red brake warning light) comes on easy... if so, then maybe the e-brake position sensor is bad... not saying for sure, because I haven't seen the car personally... just throwing out ideas...
Old Mar 3, 2008 | 05:01 AM
unsungfate's Avatar
maybe brake lines?
this may be it!... my lever has play in it and any slight and i mean SLIGHT move makes the light come on... what can i do?
Old Mar 3, 2008 | 05:04 AM
jonathan110987's Avatar
dont add fluid... replace the pads ur fluid will go back up... and no more light!
Old Mar 3, 2008 | 05:07 AM
unsungfate's Avatar
already replaced my pads... both front and rear.. haven't added fluid
Old Mar 3, 2008 | 05:09 AM
when u did ur back brakes did u readjust ur ebrake?
Old Mar 3, 2008 | 05:54 AM
BigLew's Avatar
yeah everyone is correct here about your brake fluid being low. I just went through the same thing a month ago. When I accelerated hard , the brake light will come on for a few seconds then disappear. I called my local dealership and the service adviser said that it is an indicator that the brake fluid is low and that most likely I need new brake pads. I brought it in for an oil change and brake inspection. The front pads actually was at the level where it needed to be replaced. So I got the front rotors resurfaced and brake pads changed out. They told me that you will probably go through 2 sets of front brake pads before you change out the rear pads one time.
