HELP!!! Check Engine Light popped up
Originally Posted by RoudyruffKK
thanks for the help guys i'm going to bring my car into toyota tomorrow. i'm still under warranty i checked and even basic warranty is 36mo/36k miles which still leaves me with 5k of miles left. i'll let you guys know what happens at the dealer tomorrow =)
Thanks again for all the great replies
too many customers cause there own issues.
cat is emissions, 8yr/80k
Originally Posted by JerseyTech
when u had a 30k...did u have any other work done as an addition or the basic fluids, inspections, and clean/adjust, rotate/balance?
but what code did they tell u...i wouldn't trust autozone, pepboys with a tonka truck. was it a P0420?
The cat can die early as mentioned, it does happen. But it is always good to check connections since you were under the car recently. If it is a failed cat, they should charge you for nothing, not even diagnostics. If they run diagnostics and find you caused the issue, then they will charge you for the diagnostic fee.
thanks again guys well i'm going to pick up my car tomorrow, it's all done. i did the laminate on the top of the wind visor, they also replaced my glove box because it would drop down quick instead of slowly.
when i went to fill out the paper work they weren't going to charge for the diagnostic regardless they just put it under warranty and ended up changing out the cat and exhaust manifold. thanks again guys i got everything taken care of and now i'm ready to make my 400miles drive to socal
daniinpitt
Apr 4, 2015 08:07 PM
Bakoscion46x
Jan 19, 2015 02:39 AM
