Hood install question..
Old Feb 20, 2007 | 10:00 PM
DragonR's Avatar
Default Hood install question..
I just put on my new CF hood... and when it is bolted on and lined up just right... it wont lock down...
the latch catches the hook, but it wont engage the lock that you use the hood release for...
any ideas on how i can fix this?
I have already tried to realign the bolts
the size of the hook is identical to the OE hood....
im about to take it off the bolts and see if locks that way...
Old Feb 21, 2007 | 12:12 AM
BuddhasTC's Avatar
since it is a lighter hood, you can't just drop the hood in like u used to. You gotta drop it with a little force...the bolts are probably fine
Old Feb 21, 2007 | 12:19 AM
fox's Avatar
fox
I wouldn't drop it with "force"
A friend of mine had a CF hood on his TC and he just puts it down and pushes on it a little hard above the latch. That does it!
Old Feb 21, 2007 | 12:26 AM
BuddhasTC's Avatar
eh...just a little force is not bad...i've had this same issue with all CF hoods on my past cars and would just drop it a tad bit harder than normal and never had a problem
Old Feb 22, 2007 | 12:11 AM
DragonR's Avatar
gave both of those a shot... im gonna go out and take the hood off and just place it where it supposed to be without the bolts and see if it locks that way...
thanks for the help.... keep it coming...
Old Feb 22, 2007 | 12:16 AM
ricexizxgood's Avatar
Did you try putting the stock hood back on to see if the lock works? B/C my friends lock on his s2000 broke and wouldn't engage either.
Old Feb 22, 2007 | 11:41 AM
DragonR's Avatar
what i actually tried was taking a screw driver and used the end to push down the lock... it engaged and stayed locked...
Old Feb 22, 2007 | 02:29 PM
DragonR's Avatar
I actually got it to work...
i pushed out the upper grille, b/c i was changing that too.... i closed the hood and realized that the "hook" wasnt pushing the latch down far enough to lock in place
i screwed it off... place some washer "spacers"... put the hook back on and the hood fits like a glove...
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
Archangel1183
Feb 24, 2015 09:51 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
