oil changes. anyone still using the 3,000 mile rule
Old May 13, 2008 | 06:31 AM
dieselstation's Avatar
Default oil changes. anyone still using the 3,000 mile rule
if So.. DON'T. all you're doing is wasting oil and contributing to the excess oil usage. Our tC's have 5,000 mile oil change interval recommendations from Toyota. So forget the 3,000 mile rule. It's a myth.
just do what your owner's manual says to do. The whole "change your oil every 3000 miles" rule is a myth.
http://www.autobloggreen.com/2008/01/24/the/
http://www.nordicgroup.us/oil.htm#Th...%20Mile%20Myth
http://blog.impactmt.com/2007/08/300...revisited.html
Old May 13, 2008 | 06:52 AM
SoulXquisite's Avatar
-just depends on how you drive the car.
-I use to change my oil every 3k, but with no job, i started doing it at 5k now. lol
Old May 13, 2008 | 07:01 AM
hybridsolidr's Avatar
I run Royal Purple full synthetic and do used oil analysis to check up on the engine. I also do the TBN test till I see how long I can run that oil before it loses its additive pack. My next run should be around 5,500 and then a retest.
The tC should do fine with a good quality 5w-30 oil and a toyota filter with a change interval of 5,000 miles.
Old May 13, 2008 | 07:05 AM
andino's Avatar
I do every 5k with Mobil 1 haha. I used to do 5k with regular but Costco has Mobile 1 for a good price with coupons haha
Old May 13, 2008 | 08:02 AM
BlizZard's Avatar
COSTCO FTW! lol
Old May 13, 2008 | 01:20 PM
NeverBePeace's Avatar
I changed mine like 3k ago and my maint light came on a few days ago.......it stays on now. I used mobile 1 aswell....what gives?
Old May 13, 2008 | 01:50 PM
IntegreS_350's Avatar
You're maint light is a reminder light-- It will come on automatically every 5000 mile interval, regardless of when you actually have your oil changed. You will need to manually reset it (if your dealer or mechanic doesn't).
Turn your key from the OFF position to the ON position while holding down the Trip meter reset button. Make sure your odometer is reading your actual mileage prior to doing this (and not reading Trip A or Trip B, or this will not work). Your mileage will show 6 0's then go back to your mileage and the Maint light will go off.
Old May 13, 2008 | 05:08 PM
bigwillystyle23's Avatar
good instructions^^
but yea i do my oil every 5k miles. every 3k would totally throw off my whole maintenance book because i record every time i change the oil and its premarked for every 5k
Old May 13, 2008 | 05:16 PM
nauticac's Avatar
I do mine between 3k-5k, but usually right around the 3k mark.
Old May 13, 2008 | 06:10 PM
pchavez's Avatar
Default Re: oil changes. anyone still using the 3,000 mile rule
I see a bunch of blogs that point to a site that points to a California government site, no real research. Where are your facts, man? How was this studied? What conditions, what was the size of the experiment, what was the control?
Its usually the filter that goes out before the oil does so if the manual says change at least every 5k you change at least every 5k. If you drive your car hard you won't be wrong changing the filter more often. Race cars change the engine oil, transmission oil, and filters at least every race. Pick something in between
Old May 13, 2008 | 06:25 PM
justin6969's Avatar
change ur oil at 3 k then change it at 5 k see the difference ur oil will be black at 5 k 3 k will be a little dark brown do wut u want i change mine every 3 k and flush my tanny every 20k
Old May 13, 2008 | 06:29 PM
um.. the California Integrated Waste Management Board IS the research. they did all the researching.
Old May 13, 2008 | 06:30 PM
pchavez's Avatar
I figured that out. But I didn't see a link to the research report (with data or at least a pie chart) on any of the pages linked. Is it buried in the archives somewhere?
Old May 13, 2008 | 06:31 PM
pchavez's Avatar
And what does your tranny say when he/she gets flushed?
Old May 13, 2008 | 06:32 PM
justin6969's Avatar
wut do u mean trying 2 be a smart ___?
Old May 13, 2008 | 06:41 PM
pchavez's Avatar
Ya think?!
Old May 13, 2008 | 06:44 PM
TrafficinLA's Avatar
You're suppose to change the oil?
Old May 13, 2008 | 06:45 PM
pchavez's Avatar
Only if everything starts to taste like fried shrimp.
Old May 13, 2008 | 08:35 PM
blazeplacid's Avatar
totally wrong
Black or dark oil does not mean the oil needs to be changed or that it is bad
Old May 13, 2008 | 09:01 PM
justin6969's Avatar
didint say it was good or bad just stateing id rather the oil in my car not get black
