Problem, well problems
My dome and map lights tend to flicker all the time when its on and it doesnt stop. They are all LEDs, used to work fine but recently, they've been acting weird. And also, the light in my odometer flickers when i drive or at a stopping point. Oh and another problem, everytime im driving and i put the turn signal on, my music skips, but goes back to normal after. I have the stock HU with stock speakers. 7 out of ten times the music will skip. Does anyone know what these problems are and how to fix it? thanks!
ps. i have an 07 with 9xxx miles
So is it all of your lights/electrical stuff then? Any trouble starting the car? Like does it take an extra second or two to turn over than it did before?
Could maybe have your alternator tested (and maybe battery too).
theres no trouble starting the car or anything... seems to be fine.. i dont think its all of my lights cause the trunk light doesnt flicker or anything... the odo seems to be the only one in the gauges that is actually flickering...should i go check with the dealership and have them test it out for me?
well i just called my dealership and they say it'd take 3-4 hrs, which i honestly dont know why it would... can you think of a reason why this would happen though or a quick fix it??
yeah return it to stock parts.. if problem keeps going, let the dealer replace whatever. But yeah they'll use something as simple as an aftermarket LED as the cause of the problem and refuse warranty. don't let that happen
It's a cheap excuse about an aftermarket LED. We all know that. But they just love to make you pay $$$
Originally Posted by Scorpius01
What have you been playing wih in the wire harness? what has been added?
i put my stock headlights back on...and at night when i put on my blinkers, my headlights would flicker and then dim a bit...it seems like its taking away power from the headlight so the blinker could function.. really weird...im getting it checked out next friday hopefully itll go well
Check out this thread: https://www.scionlife.com/forums/vie...r=asc&&start=0
Starting from post #7 is talk about the Big 3 as well as a couple links to a DIY
The idea is you upgrade your ground wires so electricity can flow better which usually gets rid of dimming problems
^^^ i understand that grounds could help with overall dimming due to a demand on the electrical system caused by a huge audio system.
but.. the original poster is talking about just a normal setup with flickering lights, etc. This is definitely a larger problem than just upgrading the grounds. Definitely should get that car to the dealer, something is shorting out!
