Projector Headlights - HID upgrade?
Just recently self-installed a set of projector headlights on my car, and I've run into several problems. If you have projector headlights, or know anything about them...please chime in!!!
1) The projectors don't seem to be evenly aligned. I closely examined the backside of the lights to see if there were some bolts, or something I could use to adjust them, but no luck! Any ideas? The high beams are great, and easy to align/adjust.
2) The projection isn't bright enough for me. I'm considering the possibility of upgrading to high intensity discharge (HID) headlights, and am wondering if it's possible to do. Any success stories out there?
3) My left projector light just died on me last night...so I'm thinkin' now would be a good time to upgrade to a brighter bulb.
I am not sure which projectors you have...that could help us answer you with your questions. However, I have projectors, the ones with the two led lights in the corner of each. The projectors on mine are not evenly aligned but very close nonetheless. There is basically nothing you can do to fix that though. It is a flaw based on the cheap manufacturing. I woudl adivse you to upgrade to an HID setup. Dispite the criticisms from others on this site regarding glare and what not, it increases visibility greatly for you, and looks 10x better too. I put HIDs in mine, and have not had any problems.
Hope this helps a little.
Hmmm sounds like you didn't do any research before buying your projector headlights.
Use the
button at the top of the page and you will find countless threads regarding projectors and if you can use HIDs in them or not.
Use the
which ones do you have? they most likely use H1 bulbs. check out my sale thread in case you're interested, i can try to cut you a nice deal on them if you're interested.
https://www.scionlife.com/forums/viewtopic.php?t=153149
carid
Apr 7, 2015 02:21 PM
anti_virus347
Apr 3, 2015 05:17 PM
jaspercanda
Dec 28, 2014 10:09 AM
scioninla
31
Jan 10, 2004 12:56 AM
swtbabiboi4u
Dec 28, 2003 05:48 AM
