AftrMrkt Rotors
Old Oct 7, 2006 | 02:17 AM
TeeCizzle's Avatar
Default AftrMrkt Rotors
If you purchase the Slotted or the Slotted/Drilled rotors...
Do they wear out like Reg Rotors then have to machine them too??
Just always wanted to know!...
Thanks!
Old Oct 7, 2006 | 04:05 AM
KINGxOFxSKA's Avatar
Unique Scionikz
U dont need to machine rotors unless you get yer pads to metal on the rotor face.
Old Oct 7, 2006 | 04:29 AM
TeeCizzle's Avatar
Maybe I didn't word it right..haha
Since Slotted rotors are hella expensive etc..
Do you have to Machine them just like Reg. rotors?
or Do the Slotted ones stronger and never have 2 be Machined??...
Does that make sense....sorry
Old Oct 9, 2006 | 05:16 AM
coletrein's Avatar
i think u could machine em... coz uhmm, the slots are actually chamfered/ tapered/rounded(or watever they call it) on the edges so the bit wont get stuck there...
Old Oct 9, 2006 | 01:53 PM
Otocan's Avatar
again, you NEVER have to "machine" a rotor, vibrations are caused by crappy brake pads leaving deposits on the rotors, if you ever get a vibration, buy a set of race pads and scrub the crappy padding off, then put on a set of high-quality street pads to prevent that in the future.
Old Oct 10, 2006 | 12:58 AM
TeeCizzle's Avatar
U serious?..U Not suppose to Machine rotors???...
or are ya B.S'in me??
So where do the micro grooves come from that start to show on my OEM
rotors then??
In your opinion then what Brand pads are good for OEM rotors??
Old Oct 10, 2006 | 03:01 PM
BOXMAN's Avatar
Hawk Hps
Old Oct 10, 2006 | 04:05 PM
The_Instigator's Avatar
We dont recommend machining rotors unless its a last ditch effort to remove uneven pad deposits. Wear marks and grooving on rotors are not necessarily a "bad"thing ant wont affect performance in any signifincant way. Any time material is removed from a rotor, heat capacity decreases and the rotor will be less effective at doing its job, absorb and dissipate heat.
When using factory or any aftermarket rotor, any pad labelled as a "street" compound will work just fine. Look for one that suits your needs (low dust, quiet, high bite, etc) and go with it.
Old Oct 20, 2006 | 02:47 AM
pyxy_567's Avatar
this question is for Instigator since u r the expert in this field......if I have the aftermarket cross drilled rotors for the front and rear and would like a better gripping but not for aggressive/autocross tc what brand or type of brake pads do I need....should I stick to OEM pads or aftermarkt Pads like the Hawk HPS or Deluxe AXXIS or anyother pad that you recommend......thanks!
Old Oct 20, 2006 | 03:38 AM
tc2nut4's Avatar
hawk and axxis are both good but i'm sure you'll want to hear it from instigator.. In rergards to never maching rotors, I'm sure someone else on this forum has warped atleast one set of rotors in their lifetime or is it just me
Old Oct 20, 2006 | 03:25 PM
If you arent looking for tons of initial bite (and the dust that goes laong with it) then the HPS or Deluxe plus should suit you well. Ultimates offer the more bite than either pad and have a gerat pedal feel, but also will dust quite a bit more with increased chance of noise. We have some other pads available from our parent company available which have been shown on a brake dyno to outperform some aftermarket pads while being quiet and low dust and very inexpensive that may be an option as well. PM me for details.
dougcbx
Oct 23, 2015 11:42 PM
blackpearlTC
Jul 19, 2015 04:55 PM
Dargor5
Jun 24, 2015 06:43 PM
cquencebrakes
Jun 23, 2015 09:42 PM
